Buy EcoFlow RIVER(pro) Portable Power Station — EcoFlow AU - RIVER Pro Solar Generator(PV110W)
EcoFlow Australia
D
H
M
S
EcoFlow RIVER Pro Portable Power Station
Regular price A$499.00
Sale price A$499.00 Regular price A$1,199.00
Save up to A$700
TO DOUBLE THE CAPACITY OF RIVER Pro,CLICK HERE RIVER Pro EXTRA BATTERY
• 2 x 600W AC OUTLETS AND 720Wh CAPACITY (60Ah)
• RECHARGE FROM 0-80% WITHIN 1 HOUR
• DOUBLE CAPACITY FROM 720Wh to 1440Wh
• POWER A WIDE RANGE OF APPLIANCES
A$499 A$1,199 -A$700
Step into the wild with a massive 720Wh of battery capacity. RIVER Pro is the powerhouse for your off-grid adventure. Keep multiple devices powered on at once and recharge in record times via car, solar, or standard AC outlets.
X-Stream Fast Charge
Expandable Capacity
X-Boost Output
Power Multiple Devices
The world’s fastest charging power stations
EcoFlow has the world's fastest charging power stations. RIVER Pro charges from 0-80% in under an hour, or to full in 96 minutes.
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you’ll need.
Go further
Out for the long haul? Double RIVER Pro’s capacity up to 1440Wh with an extra battery that links right to your unit.
More power to you
EcoFlow’s proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That’s enough to power a hairdryer, a vacuum cleaner.
Title
Light 10W
Refrigerator 150W
Blender 300W
Television 110W
Projector 65W
Hair Dryer 1200W
Coffee Maker 1000W
Phone 11Wh
Macbook Air 49.9Wh
GoPro 7.7Wh
Switch 16Wh
Drone 60Wh
Electric Kettle 1200W
Electric Frying Pan 1200W
Rice Cooker 1000W
Solar charging
Harness the power of the sun by linking up to two 110W solar panels. You’ll be fully charged in under 4.5 hours.
Car charging
Heading on a road trip? Charge to full in just 8-hours by plugging right into your car with the car adapter.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
1. EcoFlow RIVER Pro Portable Power Station 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
Compare The Models
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
Output: 600W (Surge 1200W)
AC Input: 500W Max
Solar Input: 200W
$1,199
RIVER Pro
Capacity:720Wh
Life Cycles: 800+ Cycle
AC Input: 660W Max
Solar Input: 200W
$1,399
DELTA
Capacity:1260Wh
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$2,399
See specs
Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W–1800W appliances with strict voltage requirements may not function (e.g. air compressors).
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER Pro in under 3 hours.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
16.8 lbs (7.6kg)
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F +/- 5°F (0 to 45°C +/- 3°C)
Discharge Temperature
-4 to 113°F +/- 5°F (-20 to 45°C +/- 3°C)
Color
Black
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 6.5 Hours (12/24V Car Adapter) 4.5-9 Hours (Using 2x 110W Solar Panels in parallel with direct sunlight)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (once fully charged)
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
230Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x2)
2x600W (Surge 1200W) total, 230Vac ( 50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5Vdc, 9Vdc, 12Vdc, 2.4A, 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
The RIVER Pro Extra Battery is sold separately.
