EcoFlow Australia
D
H
M
S
EcoFlow RIVER Max Portable Power Station (Refurbished)
Regular price A$659.00
Sale price A$659.00 Regular price A$1,598.00
Save up to A$939
• POWER WHEREVER YOU GO
• RECHARGE FROM 0-80% WITHIN 1 HOUR
• POWER UP TO 10 DEVICES SIMULTANEOUSLY
• MODULAR DESIGN
• 2 x 600W AC OUTLETS AND 576Wh CAPACITY (48Ah)
A$659 A$1,598 -A$939
Hit the outdoors with RIVER Max and keep all your devices powered on at once. With a detachable extra battery, you have up to 576Wh of capacity that charges to full in a record-breaking 96 minutes flat.
X-Stream Fast Charging
Power Multiple Devices
Removable Battery
Capacity of 576Wh
The world’s fastest charging portable power stations
EcoFlow have the world's fastest charging portable power stations. RIVER Max charges from 0-80% in under an hour, or to full in 96 minutes flat.
Go lightweight
Remove the extra battery from the base of your unit to go lightweight. Trim down to a 288Wh capacity, reducing the weight by 2.5 kg whenever you’re on the go.
The centerpiece of your adventure
Power up to 9 devices at once with all the ports you’ll need. Sporting a 576Wh capacity, you’ll have enough juice to charge your phone 42 times, charge your drone 6 times, or make 24 cups of coffee with a coffee maker. Just don’t drink them all at once.
More power to you
EcoFlow’s proprietary X-Boost technology is a game-changer. Switch it on to power high-wattage appliances up to a whopping 1800W. That’s enough to power a hairdryer, a vacuum cleaner, or even a lawnmower.
Title
Light 10W
10-20 Hours
Refrigerator 150W
Blender 300W
Television 110W
Projector 65W
Hair Dryer 1200W
Coffee Maker 1000W
Phone 11Wh
Macbook Air 49.9Wh
GoPro 7.7Wh
Switch 16Wh
Drone 60Wh
Electric Kettle 1200W
Electric Frying Pan 1200W
Rice Cooker 1000W
Take power with you wherever you go
Solar charging
Harness the power of the sun by linking up to two 110W solar panels. You’ll be fully charged in under 3 hours.
Car charging
Heading on a road trip? Charge to full in just 3.5 hours by plugging right into your car with the car adapter.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0-80% in under 1 hour with X-Stream charging.
1. EcoFlow RIVER Max Portable Power Station 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
Compare The Models
RIVER
Capacity:288Wh
Life Cycles: 500+ Cycle
Output: 600W (Surge 1200W)
AC Input: 250W Max
Solar Input: 200W
$699
See specs
RIVER Max
Capacity:576Wh
AC Input: 500W Max
Solar Input: 200W
$1,199
RIVER Pro
Capacity:720Wh
Life Cycles: 800+ Cycle
AC Input: 660W Max
Solar Input: 200W
$1,399
See specs
Each of the RIVER Series has its advantages. RIVER is ideal for lightweight, grab-and-go power, which you can expand with the extra battery. RIVER Max includes the extra battery by default, which you can remove to go lightweight. RIVER Pro is made for those that need even more capacity for off-grid, long haul adventures.
Yes. You can control RIVER Max using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Max can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W-1800W appliances with strict voltage requirements may not function (eg. air compressors).
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Max is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Max automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
RIVER Max supports entry-level UPS functionality. Make sure to perform multiple tests to confirm compatibility before connecting devices such as data servers and workstations with RIVER.
7.7kg
11.4 x 7.3 x 9.3in (28.9 x 18.4 x 23.5cm)
Charge Temperature
32-113°F +/- 5°F (0-45°C +/- 3°C)
Discharge Temperature
-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color
Black
Charge Method
AC Wall Outlet, 12V Car Adapter, Solar Panel
Full Recharge Time
1.6 Hours (AC) 6.5 Hours (12/24V Car Adapter) 3-6 Hours (Using 2x110W Solar Panels in parallel with full sun)
576Wh (28.8V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (after fully charging the device)
500 Cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certification
UL Standard CE FCC RoHS RCM
AC Charge Input Power
X-Stream Charge 500W max
AC Charge Input Voltage
230Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25V DC 12A Max
Car Charger
12V DC 8A Max
AC Output (x2)
600W (Surge 1200W) total,230Vac( 50Hz/60Hz)
USB-A Output (x2)
5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x1)
5V DC,9V DC,12V DC,2.4A,18W Max
USB-C Output (x1)
5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
Car Power Output (x1)
136W, 13.6V DC, 10A Max
DC5521 Output (x2)
13.6V DC, 3A Max, per port
