EcoFlow Power Hat | Wearable Solar Charger | EcoFlow AU - Power Hat M-L (56-58 cm)- Member discount
EcoFlow Australia
D
H
M
S
EcoFlow Power Hat
A$179.00
EcoFlow Power Hat
Regular price A$179.00
Sale price A$179.00 Regular price A$179.00
*Size:
Medium-Large size: 56-58 cm
Large-XLarge size: 59-61 cm
  • Solar charging on the go
  • Captures solar energy from all angles without any blind spots.
  • Dual USB-A & USB-C ports for charging two devices simultaneously.
  • Lightweight at only 370 g, easy to pack.
  • IP65 waterproof and dust proof-rated, ideal for hiking, beach trips, fishing, and outdoor activities.
  • Available in two head sizes M:58/L:61 cm with adjustable hook and loop for the perfect fit.
Size
EcoFlow 12V 100Ah Lithium Trolling Motor Battery
A$499 A$699
1280Wh Capacity
1280W Continuous Output
EcoFlow Camping Chair
A$99
EcoFlow Flatbed Trolley
A$129
EcoFlow Camping Light (7200mAh)
A$109 A$129
EcoFlow Camping Mug
A$49
A$499 A$699
1280Wh Capacity
A$99
A$109 A$129
A$129
EcoFlow Camping Mug
A$49
A$179
Adjustable M to XL size
Featuring an adjustable hook-and-loop design inside the hat for a snug fit without obstructing vision.
360-Degree coverageSolar charging on the go
Traditional solar panels require adjusting to ensure optimal sunlight exposure. EcoFlow Power Hat maintains the optimal angle at all times, eliminating the need for manual adjustments. It charges a mobile phone fully in as fast as 3-4 hours.
*Assuming the phone battery capacity is 4000mAh
Dual USB-A/USB-C ports
Charge two devices at the same time. Run small appliances such as neck fans, Bluetooth headphones, and mobile phones.
370g
Ultra-lightweight
At only one-eighth the thickness of conventional solar panels, it's lightweight, thin, and comfortable for extended wear. Easily folds and fits into a backpack for convenient storage, making it the ideal choice for outdoor hiking.
370g<br>Ultra-lightweight
IP65 Waterproof and Dustproof-rated Suitable for outdoor use
Works well in wet environments like by the sea or lake, and can be used in light rain. Resistant to sand and dust, splash-proof, and crack-resistant, making it durable and suitable for outdoor use without needing delicate handling.
Suitable For Outdoor Scenarios
Ideal for hiking, mountain climbing, fishing, beach outings, outdoor tasks, and more. Perfect for solar charging during an outdoor activity while also providing sun protection.
What's In The Box
Rated Power
STC12W(+/-1w)
Cell Type & Efficiency
Perc Monocrystalline Silicon, 23-24%
Medium-Large: 7 - 7 1/4/ 56-58 cm
Large-X-Large: 7 3/8 - 7 5/8 / 59-61 cm
Open Circuit Voltage
7.8V
370g
Maximum Operating Voltage
6V
Output Ports
USB-A/USB-C
Maximum Operating Current
2A
Output
5V 2.4A Max
Short Circuit Current
2.2A
Waterproof & Dustproof
IP65
