EcoFlow DELTA Pro 3 Smart Extra Battery | EcoFlow AU - DELTA Pro 3 Smart Extra Battery
EcoFlow Australia
Regular price A$3,999.00
Sale price A$3,999.00 Regular price A$3,999.00
Compatibility - Works seamlessly with EcoFlow DELTA Pro 3 (The EcoFlow DELTA Pro Smart Extra Battery is compatible with the EcoFlow DELTA Pro 3. ).
Scalable Power - Expandable up to 12kWh for increased capacity.
Long-Lasting Battery - LFP battery with 4000 life cycles to 80% capacity.
Easy to Use - Plug-and-play design for straightforward operation.
Stackable Design - Perfect for home or indoor power backup applications
Type
EcoFlow Extra Battery Flat Link Cable
A$158
A$3,999
Plug and Play
The smart extra batteries are easy to connect with the main unit of EcoFlow DELTA Pro 3.
Enjoy a seamless, plug-and-play setup. The compact and portable design adds
convenience to your power management.
Explore the Secure Feeling
EcoFlow Brings to You
Built with state-of-the-art automotive-grade LFP cells for safe and reliable service. Our
strong 5-year warranty ensures peace of mind.
Energize Every Moment
That Needs Electricity
Power almost all your essential home appliances with the robust 4000W and 230V capabilities of a
single unit. Add extra batteries to extend the convenience even further.
Off-grid
RV
Jobsite
Cutting-Edge Design, Sleek
And Striking
0 Ms Downtime, 0 dB Silent BackupBoosts portability with wider wheels, ergonomic handle, and a compact design. Perfect
for dynamic lifestyles and maximizing family space.
Effortless All-in-One Command
With the EcoFlow App
0 Ms Downtime, 0 dB Silent BackupControl and monitor your home's power remotely with ease using the EcoFlow app. Track
every watt and customize your power usage for optimal efficiency.
What's In The Box?
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.
Can EcoFlow DELTA Pro 3 output 120V and 240V AC power simultaneously?
No, but it can perform split-phase output as a standalone unit.There are two buttons for AC output: 120V AC ON/OFF and 240V AC ON/OFF.1. When the 120V AC button is pressed, four 120V 20A outlets and one 30A RV outlet will supply power, and the 240V outlet will be turned off.2. When the 240V AC button is pressed, one L14-30 split-phase outlet and one 6-20R 240V outlet output power, and the 120V outlet will be turned off.
Will EcoFlow DELTA Pro 3 automatically turn on if connected to solar panels while it is turned off?
Yes, it will.However, there are specific requirements for the light conditions. In weak lighting environments, it might not trigger the device to power on.
  1. EcoFlow 800W Alternator Charger
  2. EcoFlow Smart Generator (Dual Fuel)
  3. EcoFlow DELTA Pro to Smart Generator Adapter
  4. EcoFlow WAVE 2
Which EcoFlow products are compatible with EcoFlow DELTA Pro 3? (EcoFlow DELTA Pro series)
  1. EcoFlow DELTA Pro Smart Extra Battery
  2. EcoFlow EV X-Stream Adapter (DELTA Pro Ultra)
  3. EcoFlow DELTA Pro Remote Control
How long is the cycle life of the battery in EcoFlow DELTA Pro 3?
4000 cycles.After undergoing 4000 cycles at a rate of 0.5C/0.5C at 25°C (77°F), the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°CCharging temperature range: 0℃-45℃Discharge temperature range: –10℃-45℃Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device. Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs. When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Is the EcoFlow DELTA Pro Smart Extra Battery compatible with the EcoFlow DELTA Pro 3?
Yes, supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
Can the EcoFlow DELTA Pro 3 Smart Extra Battery and the EcoFlow DELTA Pro Smart Extra Battery be mixed and plugged into the EcoFlow DELTA Pro 3?
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
