Solar Generator EcoFlow DELTA Pro 3 400W Solar Panel | EcoFlow AU - DELTA Pro 3 + 2*400W Portable Solar Panel
EcoFlow Australia
D
H
M
S
A$6,239.00
Regular price A$6,239.00
Sale price A$6,239.00 Regular price A$7,599.00
Save up to A$1,360
Powerful and Versatile - 230V, 4000W in a single unit to power almost all of your home appliances.
Capacity - 4–12kWh Capacity, tailored to your energy needs.
Quiet Operation - Operates as low as 30 dB (under 2000W) for minimal noise.
Easy to Use - Plug-and-play design for hassle-free setup.
Fast Charging - Charges to 80% in just 50 minutes.
Multiple Charging Methods - 6 unique and 18 combo charging methods for maximum flexibility.
Type
A$6,239 A$7,599 -A$1,360
For Those Concerned About Electricity Cost Savings Through Self-Consumption
Start an energy-saving lifestyle without the need for electrical work. With the DELTA Pro 3, you can create a home energy storage system without a grid connection, cutting down on installation costs. Store solar energy in the DELTA Pro 3 during the day and use it at night to power your household appliances, saving approximately 22% on daily energy consumption with just one unit. Add an extra battery to save 44%, and two extra batteries to save up to 66% per day.
Keep Your Home Running Smoothly
Ensure essential appliances keep working
4000W High Output
A comprehensive 10 ms UPS
A single DELTA Pro 3 unit has a 4kWh battery capacity, easily meeting the electricity needs of a household, providing peace of mind even in emergencies. Additionally, the capacity can be expanded to 12kWh*, allowing you to use the stored power in the DELTA Pro 3** even during several hours of a power outage.
Multiple high-power household appliances can be used simultaneously. EcoFlow's unique X-Fusion technology allows the DELTA Pro 3 to output 4000W, even when the input is AC230V 2900W. The more stable pure sine wave output ensures an enjoyable experience when using household appliances.
Ensures swift 10ms switch-overs, protecting your NAS systems, servers, and entertainment devices from power disruptions, keeping your technology safe and continuously powered.
State-of-the-art LFP Tech
Powered by ground-breaking X-Guard BMS
Revolutionizing Durable Construction
5 Years Warranty, Zero Worries
Crafted with automotive-grade LFP cells, the EcoFlow DELTA Pro 3 features the industry's first IP65-rated battery pack, resisting impacts, water, dust, and fire. With 4000 cycles to 80%, enjoy 11 years* of daily power. Dependable in any weather, ensuring peace of mind.
*Tested under controlled laboratory conditions with charging and discharging at 0.5C rate under 77°F conditions
X-Guard BMS monitors 40 safety indicators 24/7, app-managed for smart, secure energy.
CTC design, UL-certified 5VA fireproof shell fortify DELTA Pro 3, setting new standards for resilience.
5-year warranty, streamlined support for swift solutions, minimal downtime. Quality redefined.
Charge Up, Fast, and Everywhere
Introducing EcoFlow's groundbreaking X-Stream fast charging technology, setting a new industry standard. Charge from 0 to 80% in just 1 hr. With multi-charge combinations, enjoy up to 7000W of super-fast charging.
Effortless All-in-One Command with the EcoFlow App
Effortless Portability and Space-Efficient
Portable design for an ideal lifestyle. Boosts portability with its wide wheels, ergonomic handle, and compact design. Its magnetic sliding doors simplify access, optimising space and power for mobility without compromise. Ideal for dynamic lifestyles and maximising family space.
Multiple Using Scenario
Equipped with a portable home battery, ensuring peace of mind in emergencies.
Equipped with a TT30 port to power RVs.
Achieve off-grid capability with solar panels and the DELTA Pro 3.
With powerful output and expandable capacity, it's ideal for various high-power appliances.
6 unique and 18 combo charging methods to meet your charging needs anywhere, anytime.
Indoor: Dual-PV Charging
Indoor: AC Wall Charging
Backyard: With Gas
Generator
Outdoor: EV Charging
Piles
RV/Van: EcoFlow
Alternator Charger
Car: Cigarette Lighter
Charging
Fast Multi-Charging
Solutions
Quiet Comfort for Your Home and Neighbors
It's whisper-quiet with X-Quiet technology, ensuring a peaceful hum*, promising you a night of peaceful sleep even if you keep it beside your bed. It's so silent that you'll hardly notice it's there.
*as low as 30 dB, thanks to our X-Quiet tech
Choose the Product That Suits You Best
What's In The Box?
4096Wh
5 outlets, 4000W max. (Surge 8000W)
X-Boost 6000W, Supports up to two DELTA Pro 3 Smart Extra Batteries
DC Output
7 Outlet
2x USB-A, 5V 2.4A 9V 2A 12V 1.5A 18W Max
2xUSB-C, 5/9/12/15/20V 5A 100W Max.
1×DC5521,5AMax
1xAnderson,30A Max
1x Remote Control Port
Solar Charging Input
2600W
Connection
Wi-Fi 2.4GHz/Bluetooth
693×341×410 mm
Car Charging Input
12V 8A max.
48V 20A max.
51.5 kg (113.54 lb)
Compatiblity
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.
Will EcoFlow DELTA Pro 3 automatically turn on if connected to solar panels while it is turned off?
Yes, it will.However, there are specific requirements for the light conditions. In weak lighting environments, it might not trigger the device to power on.
  1. EcoFlow 800W Alternator Charger
  2. EcoFlow Smart Generator (Dual Fuel)
  3. EcoFlow DELTA Pro to Smart Generator Adapter
  4. EcoFlow WAVE 2
Which EcoFlow products are compatible with EcoFlow DELTA Pro 3? (EcoFlow DELTA Pro series)
  1. EcoFlow DELTA Pro Smart Extra Battery
  2. EcoFlow DELTA Pro Remote Control
How long is the cycle life of the battery in EcoFlow DELTA Pro 3?
4000 cycles.After undergoing 4000 cycles at a rate of 0.5C/0.5C at 25°C (77°F), the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°CCharging temperature range: 0℃-45℃Discharge temperature range: –10℃-45℃Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device. Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs. When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Is the EcoFlow DELTA Pro Smart Extra Battery compatible with the EcoFlow DELTA Pro 3?
Yes, supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
Can the EcoFlow DELTA Pro 3 Smart Extra Battery and the EcoFlow DELTA Pro Smart Extra Battery be mixed and plugged into the EcoFlow DELTA Pro 3?
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
