A$2,359.00
To reach 1000W input, DELTA 3 Max Plus / DELTA Pro 3 / DELTA Pro must use theSmart Generator Adapter. Included free in bundles
*To enable solar charging, the EcoFlowAlternator Charger Plus 1000 Solar Input Cable (12AWG, 5m) is required.
Charge as you drive – 10× faster than a traditional car cigarette lighter. Power up 1kWh in only 1 hour and arrive with a fully charged portable power station.
*Tested using a 12V car charging system at 25 ℃ ambient temperature. Actual performance may vary by vehicle and environment.
By connecting solar directly to the alternator charger port, you free up the XT60 port on your portable power station. This allows you to use both the alternator charger and solar panels at the same time.
* To enable solar charging, the EcoFlowAlternator Charger Plus 1000 Solar Input Cable (12AWG, 5m)is required.
Turn off solar charging in the app to draw up to 1000W from the alternator alone.
Turn on solar charging in the app to combine 700W from the alternator + up to 300W from solar, reaching a maximum of 1000W input.
An industry first: supports car infotainment connectivity, compatible with Apple CarPlay and Android Auto interfaces
Monitor real-time starter battery voltage, portable power station SOC, and remaining charging time directly on your vehicle’s infotainment screen. Adjust charging modes on the go to manage power station status—everything at your fingertips.
The Alternator Charger harnesses surplus alternator power without disrupting normal vehicle operation or adding extra load while driving.
Built-in ignition cable ensures compatibility with smart alternators. The charger shuts down instantly when the engine stops, preventing starter battery drain.
Output adapts automatically to starter battery voltage and the forward charging voltage set in the app, preventing excessive drops.
Safeguards against overcurrent and short circuits, ensuring stable, reliable operation.
Follow the step-by-step guide and get set up in minutes.
Buy a DELTA 3 Max Plus / DELTA 3 Ultra Plus / DELTA Pro / DELTA Pro 3 with an 800W or 1000W Alternator Charger bundle, get Custom Output Cable or Smart Generator Adapter for free.(Smart Generator Adapter arrives in mid-April.)
* DELTA 2/DELTA 3/ DELTA 3 Plus/DELTA 3 1500 support 1000W input directly.
Approx. 1.7 kg
276×187×38 mm
ALT IN Port Input
12V/24V⎓(11V-31V⎓), 75A Max
Charging Mode
ALT IN Port Input: 12V/24V⎓(11V-31V⎓), 75A Max
Battery Port Output: 24V⎓/40V-60V⎓, 20A Max, 1000W Max
Charging Mode (Solar Only)
Input: 11–60V, 15A max, 300W max (SOLAR port)
Battery Maintenance Mode
ALT IN Port Output: 13.8V/27.6V⎓, 100W Max
Battery Port Input: 40V-60V⎓, 3A Max
Reverse Charge Mode
ALT IN Port Output: 13.8V/27.6V⎓, 75A Max
Battery Port Input: 40V-60V⎓, 20A Max
Rated Current of Fuse
125A
Operating Temperature
–10℃ to 45℃ (14℉ to 113℉)
Storage Temperature
–30℃ to 70℃ (–22℉ to 158℉)
Protection Type
Reverse polarity protection/Overcurrent protection/Short circuitprotection/Overvoltage and undervoltage protection/Storage BatteryOver-discharge Protection(Provided with integral protection against overloads)
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
