Weekend Flash Sale🔥 Shop Now >
Charge 5× faster while you drive with our EcoFlow 500W Alternator Charger and recharge your power station in only 2.1 hours.With the EcoFlow 500W Alternator Charger, charge 5 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
Compatible with an XT60 connection, designed to charge EcoFlow RIVER, DELTA Series, and most third-party power stations. The charger's 500W fast-charging is compatible with most SUV, Pickup, and RV alternators, meeting diverse short-trip car camping power needs.
Conveniently adapts to 12V/24V 4WD batteries. Connects to EcoFlow portable power stations and protects 4WD batteries while expanding energy storage capacity by up to 7.2kWh*.* With EcoFlow DELTA 3 Pro and DELTA 3 Pro Extra Battery.
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time. The 500W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Model
EF-MS-H02-1
5.7 kg
Dimensions (W × D × H)
242×194×35 mm
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: 18.22dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: 7.89dBm
Charging Mode
Input: 12V/24V⎓(11V-31V⎓), 45A Max.
Output: 40V-60V⎓, 500W Max.;24V⎓, 360W Max.
Battery Maintenance Mode
Input: 40V-60V⎓, 3A Max.
Output: 13.8V/27.6V⎓, 100W Max.
Reverse Charging Mode
Input: 40V-60V⎓, 13.2A Max.
Output: 13.8V/27.6V⎓, 500W Max.
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection / Overcurrent protection / Short circuit protection / Overvoltage and undervoltage protection (Provided with integral protection against overloads)
Yes, the Alternator Charger can charge third-party portable power stations if the following conditions are met:1. Connected via an XT60 cable.2. The battery type is correctly configured in the settings.3. The vehicle battery voltage (12V/24V) is selected based on the actual voltage level.4. The portable power station type is set to third-party 24V battery.
Cable length settings compensate for voltage drop, ensuring accurate voltage readings.Recommendation: Set based on actual measured length of the input cable.
The Alternator Charger uses a boost circuit design, requiring the input voltage to be lower than the output voltage for safe, optimal performance.
Very minimally. The product uses the power generated by the vehicle's alternator. Even if all the electrical devices inside the car are turned off, the alternator still generates power while the vehicle is running. The Alternator Charger harnesses the surplus power generated by the car's alternator and stores it in a portable power station through the charger. The impact on fuel consumption is very minimal.
No drilling is needed. Wiring routes through the firewall near the driver'’s seat. Installation is safe and will not cause damage.
Yes, for users with hands-on experience. However, it is still recommended to contact professional personnel from related workshops for installation.Tip: Avoid hot, sharp, or high-friction areas. Secure all cables and never cover the unit. It may get hot, so avoid direct contact immediately after use.
It delivers up to 500W of power—5× more than the average 100W from a cigarette lighter—allowing faster, more efficient charging while driving.
It works best with fuel-powered, hybrid, and range-extended vehicles.Charging power depends on alternator surplus and may vary with vehicle age or design.
It uses voltage recognition with an adjustable start voltage range of 11V–30V.
Yes, in Reverse Charging Mode via the EcoFlow app (requires XT150 cable and DELTA Series product).
The charger supports 11V–31V input, making it suitable for most 12V or 24V vehicle starter batteries.
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
