EcoFlow 500W Alternator Charger for Vehicles | EcoFlow AU - RIVER 3 Plus + 500W Alternator Charger
EcoFlow Australia
D
H
M
S
A$159.00
Regular price A$159.00
Sale price A$159.00 Regular price A$159.00
- 5x faster than traditional in- vehicle auxiliary power outlets. 500W (45A@12V*) input.
- 2.1 hrs to fully charge 1kWh (85Ah@12V).
- A 3-in-1 fast charger, maintainer, and jump starter keeps your battery in mint condition.
- 3-step easy installation
- Suitable for a variety of vehicles, including SUVs, pickups, and RVS.
* The 500W Alternator Charger includes only XT60i cable in the box and does not support reverse charging & battery maintenance functions with XT60 cable. To enable reverse charging & battery maintenance functions, additional purchase of XT150 cable is required.
* When used with third-party portable power stations, the 500W Alternator Charger does not support reverse charging & battery maintenance functions.
*When using an XT60 cable, the Alternator Charger switch on the device must be manually turned on and the charging function enabled in the app before charging can begin. Therefore, if planning to use the XT60 cable for output, avoid concealed installation of the Alternator Charger in advance.
A$159
  • Note: The terms "DELTA" and "RIVER" as mentioned on this page refer to products exclusively manufactured by ECOFLOW INC. RIVER/RIVER 2/RIVER 3 series only support XT60 port. Delta series both supports XT60 and XT150 ports.
  • Note: When installing the Alternator Charger main unit, make sure not to block the power button. After connecting the Alternator Charger to the portable power station(both River and Delta Series) via the XT60 port, you need to press the power button each time you turn on the car to turn it on before initiating charging through the app.
Top up 1kWh (85Ah@12V) in only 2.1 hours
Charge 5× faster while you drive with our EcoFlow 500W Alternator Charger and recharge your power station in only 2.1 hours.With the EcoFlow 500W Alternator Charger, charge 5 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
The 3-in-1 charger, maintainer, and jump starter saves time, money, and precious in-vehicle space.
* The 500W Alternator Charger comes with an XT60 cable, but does not support reverse charging & battery maintenance functions with the XT60 cable. To enable reverse charging & battery maintenance functions, purchase the XT150 cable and use with an EcoFlow DELTA Series product.
Charging Mode
Reverse Charging Mode
Battery Maintenance Mode
Charging Mode
Charging Mode
Compatible with all EcoFlow and most third-party power stations
Compatible with an XT60 connection, designed to charge EcoFlow RIVER, DELTA Series, and most third-party power stations. The charger's 500W fast-charging is compatible with most SUV, Pickup, and RV alternators, meeting diverse short-trip car camping power needs.
Traditional vs. EcoFlow Portable Dual Battery Systems
How to Choose your EcoFlow Alternator Charger
*Not compatible with discontinued models: DELTA 1300, DELTA 1600, DELTA Mini, DELTA Max.
Extend your 4WD battery runtime
Conveniently adapts to 12V/24V 4WD batteries. Connects to EcoFlow portable power stations and protects 4WD batteries while expanding energy storage capacity by up to 7.2kWh*.* With EcoFlow DELTA 3 Pro and DELTA 3 Pro Extra Battery.
Connect your 500W Alternator Charger to your vehicle's starter battery or RV's house battery to enjoy a worry-free power experience during your journey.
Connect the Fuse Cable
Connect the Input Cable
Start Charging
1. Connect the fuse cable to the input cable on one end.
2. Connect the fuse cable to the vehicle battery on the other end.
1. Connect the black cable to the chassis terminal.
2. Thread the other end of the input cable through the car body towards the charger. If the input cable is bulky or difficult to pull through, disconnect the cable ends before threading.
3. Plug the other side of the input cable into the EcoFlow 500W Alternator Charger.
Plug in the output cable from the EcoFlow 500W Alternator Charger to the portable power station.
Start Charging
Start Charging
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time. The 500W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Model
EF-MS-H02-1
5.7 kg
Dimensions (W × D × H)
242×194×35 mm
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: 18.22dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: 7.89dBm
Charging Mode
Input: 12V/24V⎓(11V-31V⎓), 45A Max.
Output: 40V-60V⎓, 500W Max.;24V⎓, 360W Max.
Input: 40V-60V⎓, 3A Max.
Output: 13.8V/27.6V⎓, 100W Max.
Input: 40V-60V⎓, 13.2A Max.
Output: 13.8V/27.6V⎓, 500W Max.
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection / Overcurrent protection / Short circuit protection / Overvoltage and undervoltage protection (Provided with integral protection against overloads)
Is the EcoFlow Alternator Charger compatible with third-party power stations, and how are they charged?
Yes, the Alternator Charger can charge third-party portable power stations if the following conditions are met:1. Connected via an XT60 cable.2. The battery type is correctly configured in the settings.3. The vehicle battery voltage (12V/24V) is selected based on the actual voltage level.4. The portable power station type is set to third-party 24V battery.
Why can't the maximum power be reached when using the XT60 cable?
  1. Output is capped at 500W when using an XT60 cable, even for the 800W Alternator Charger.
  2. If the portable power station is set to 48V, max output is 500W. For 24V, it drops to 360W.
  3. Actual power depends on the station’s input capability. The 500W/800W/360W ratings refer to charger output, not the station’s input.
Why do I need to set the cable length?
Cable length settings compensate for voltage drop, ensuring accurate voltage readings.Recommendation: Set based on actual measured length of the input cable.
Why can't I select 24V as the power station type (RIVER 2/3/mini/Max/Pro, WAVE, & third-party 24V batteries) when the vehicle battery is set to 24V?
The Alternator Charger uses a boost circuit design, requiring the input voltage to be lower than the output voltage for safe, optimal performance.
Will the Alternator Charger affect fuel consumption?
Very minimally. The product uses the power generated by the vehicle's alternator. Even if all the electrical devices inside the car are turned off, the alternator still generates power while the vehicle is running. The Alternator Charger harnesses the surplus power generated by the car's alternator and stores it in a portable power station through the charger. The impact on fuel consumption is very minimal.
Do I need to drill holes to install it? Will it damage the vehicle?
No drilling is needed. Wiring routes through the firewall near the driver'’s seat. Installation is safe and will not cause damage.
Is the Alternator Charger suitable for DIY installation?
Yes, for users with hands-on experience. However, it is still recommended to contact professional personnel from related workshops for installation.Tip: Avoid hot, sharp, or high-friction areas. Secure all cables and never cover the unit. It may get hot, so avoid direct contact immediately after use.
What advantages does the 500W Alternator Charger offer over a cigarette lighter?
It delivers up to 500W of power—5× more than the average 100W from a cigarette lighter—allowing faster, more efficient charging while driving.
Which vehicles are compatible, and can all reach maximum power?
It works best with fuel-powered, hybrid, and range-extended vehicles.Charging power depends on alternator surplus and may vary with vehicle age or design.
How does the Alternator Charger start and stop automatically?
It uses voltage recognition with an adjustable start voltage range of 11V–30V.
Can the Alternator Charger recharge the vehicle battery?
Yes, in Reverse Charging Mode via the EcoFlow app (requires XT150 cable and DELTA Series product).
How long does it take to fully charge EcoFlow products with the 500W Alternator Charger?
  • RIVER 2: 2.4 hr
  • RIVER 2 Plus: 2.6 hr
  • RIVER 2 Pro / RIVER 2 Max: 3.5 hr
  • RIVER 3: 2.4 hr
  • DELTA 2 (1kWh): 2.4 hr
  • DELTA 3 / DELTA 3 Plus (1kWh): 2.5 hr
How do I know if my vehicle is compatible?
The charger supports 11V–31V input, making it suitable for most 12V or 24V vehicle starter batteries.
How many working modes does the Alternator Charger have?
  1. Charge Mode: Uses the vehicle’s alternator to charge the power station.
  2. Reverse Charge Mode: Uses the power station to charge the vehicle/RV battery with high current (XT150 + DELTA required).
  3. Battery Maintenance Mode: Similar to reverse charging, but lower current (max 100W) for battery longevity (XT150 + DELTA required).
