EcoFlow 400W Lightweight Portable Solar Panel - 400W Lightweight Solar Panel - Member Price
EcoFlow Australia
Regular price A$1,299.00
Sale price A$1,299.00 Regular price A$1,299.00
· Built-in XT60 cable for easy storage and connection to power stations
· Lightweight and compact for portability
· Up to 25% conversion efficiency rate with a bifacial design
· 3-angle (30°/45°/60°) adjustable stand and integrated solar angle guide
· IP68 rating protects against water and dust
* This lightweight portable solar panel is not recommended for certain scenarios, such as hanging long-term outdoors or on vehicles.
Type
A$1,299
Capture More Energy with Bifacial Design
With primary and rear-side panels for ambient light, output power reaches up to 445W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, the portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel weighs just 10.2kg—5.8kg lighter than previous models—for effortless transport and compact storage.
Built-in XT60
The integrated XT60 cable makes it easier to store and connect to portable power stations for a faster setup.
Built-in XT60
Built-in XT60
Built-in XT60
Built-in XT60
Built-in XT60
Built-in XT60
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most light at all times.
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, it's ideal even for most high-latitude areas.
* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended for this scenario.
Durable and Water-Resistant
Built to Weather the Storm
With an IP68 water-resistance rating, our 220W Lightweight Portable Solar Panel maintains its high performance even when in contact with water. You can safely recharge in wet conditions, such as seaside or on a boat.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solargeneration.
5-Year Warranty
What’s in the box
Rated Power
400W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
Approx. 10.2 kg
Unfolded: 2509 x 967 x 26 mm
Folded: 659 x 967 x 36 mm
Connector Type
XT60
Built-in cable length: 8.20 feet
5 Years
Open Circuit Voltage
39.3V (Vpm 34.5V)
Short Circuit Current
12.2A (Ipm 11.7A)
Waterproof & Dustproof
