EcoFlow Australia
EcoFlow DELTA Max Portable Power Station (Refurbished)
Regular price A$999.00
Sale price A$999.00 Regular price A$2,799.00
Save up to A$1,800
• 2-6kWh expandable capacity for home backup;
* DM(2000): 170Ah@12V;
• Power heavy-duty devices with 2400W output
• Charge 0-80% in just 65 minutes
• Solar charge in as fast as 2.5 hours
• Up to 3400W fast dual charging
• Smart app control
A$999 A$2,799 -A$1,800
Expandable Capacity
Dual Charging
Power multiple devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3400W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.
With EcoFlow's X-Boost technology, DELTA Max can power heavy-duty devices up to 3000W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That's the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the MC4 connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Title
Light 10W
CPAP 40W (AC)
Refrigerator 120W (AC)
Microwave 1300W (AC)
Washer 500W (AC)
50
Hair Dryer 1600W (AC)
Coffee Maker 1000W (AC)
Electric Frying Pan 1200W (AC)
Phone 11Wh (Type-C)
Laptop 60Wh (Type-C)
Camera 16Wh (USB)
Drone 40Wh (Type-C)
Speaker 10W (AC)
Blender 500W (AC)
Car Fridge 60W (DC)
Projector 65W (AC)
PS5 200W (AC)
Circular Saw 1400W (AC)
Air Conditioner 1800W (AC)
Electric Hammer 1260W (AC)
Electric Drill 1080W (AC)
Cutting Machine 1100W (AC)
Electric Oven 1650W (AC)
Electric Grill 1150W (AC)
Air fryer 1500W (AC)
Multiple ways to charge.
What's in the Box
1.DELTA Max (1600/2000) 2. DC5521-DC5525 Cable 3. 1.5m AC Charging Cable 4. 1.5m Car Charging Cable 5. User Manual 6. Warranty Card
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (2000W max)
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
AC Charging Input
2000W Max, 10A
Solar Charging Input
11-100V 13A Max, 800W max
Car Charging Input
Supports 12V/24V Battery, Default 8A
NCM
Cycle life
800 cycles to 80% capacity
Shelf Life
1 year (after a full charge)
Connection
Wi-Fi
Approx. 48 lbs (22 kg)
Dimension
19.6 x 9.5 x 12 in (49.7 x 24.2 x 30.5 cm)
Specs of DELTA Max (1600)
1612Wh
Extra Battery
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
AC Charge Input (Voltage and Amperage)
1600W Max, 10A
Car Charging Input
NCM
Cycle life
500 cycles to 80% capacity
Shelf Life
Connection
Wi-Fi
Dimension
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
