DELTA 2 Max Portable Power Station | EcoFlow AU - DELTA 2 Max (2048)
EcoFlow Australia
A$2,099.00
Sale Ends in
Days
Hours
Minutes
Seconds
Regular price A$2,099.00
Sale price A$2,099.00 Regular price A$2,599.00
Save up to A$500
Expandable capacity: 2-6kWh expandable capacity (167Ah@12V) to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Huge AC output: With X-Boost mode, get up to 3100W output power to run 99% of home appliances. Power 13 devices at once, including 4 AC outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty:24+36 (Registration for warranty extension)
Bundle Options
EcoFlow DELTA 2 Max Bag
A$159
A$159
A$39.90
A$39.90
A$159
A$39.90
A$2,099 A$2,599 -A$500
EcoFlow DELTA 2 Max
Max Power. Less Weight
Why Choose DELTA 2 Max?
Power Pretty Much Anything with 3100W Max Output
4 ways of industry-leading fast charging
*Fuel Up 80% in Only 43 Mins
AC + Solar Dual Charging
AC Charging
Car Charging
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. *When combined AC and solar input is 2400W using 1800W AC input and a maximum of 600W solar input.
AC charging for an 80% recharge in a speedy 53 mins.
Dual Solar Input System with Independent MPPT Technology maximize the potential of solar energy by simultaneously utilizing multiple photovoltaic (PV) sources with our innovative dual solar input design, each with its independent Maximum Power Point Tracking (MPPT) technology.
Charge 2kWh in 2.6 hrs via 800W Alternator Charger —8× faster than conventional options, eliminating pre-charging hassles during travel.
Power for Every Scenarios
Outdoor Camping
RVing
Home Backup
Professional Work
Why EcoFlow DELTA Max Series Stands Out?
Ultra-Powerful, Lightweight 2kWh Portable Power. Flexible Options Across All Kinds of Needs
Expandable Up to 6kWh via Stackable Extra Batteries
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity bills. Customize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages. With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power ready. Get a notification via the app when the battery hits a low.
10 Years of Reliable Power
Durable, Safe, Lightweight
LiFePO4 battery
Advanced BMS Protection
5-Year Warranty
Upgraded Tech, Robust Design, Lighter Weight Upgraded Tech, Robust Design, Lighter Weight
As Quiet as 30 dB Peaceful charging
At only 30 dB, DELTA 2 Max is quieter than other 2kWh power stations on the market.*From a distance of approximately 20 in., noise level is 30 dB (with low input and 500W output) vs. other power stations with 55 dB or higher.
What’s in the box
Battery
2048Wh (167Ah@12V)
Extra Battery
Supports up to two DELTA 2 Max Smart Extra Batteries
Cycle life
3000 cycles to 80+% capacity
LFP (LiFePO4 battery)
Output
Max Device Power
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
Input
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
220-240V~10A 50Hz/60Hz
1-60V 15A, single port 500W; dual port 1,000W
Car Charging
Support 12V/24V battery, 8A
General
497 × 242 × 305 mm
Net weight (kg)
23 kg
Connectivity
Wi-Fi & Bluetooth
