DELTA 2 Max + 220W Solar Generator | EcoFlow AU
EcoFlow Australia
EcoFlow DELTA 2 Max Solar Generator (PV220W)
$2,549.00 AUD
Regular price $2,549.00 AUD
Sale price $2,549.00 AUD Regular price $3,298.00
Save up to $749
- 6kWh expandable capacity
- 10-year LFP battery life
- 3100W X-Boost AC output
- Fast 2.3 hr full solar charge
Style
EcoFlow DELTA 2 Max Bag
$159 AUD
$549 AUD $599 AUD
800W(70A@12V*) input, 1.3 hrs to fully charge 1kWh (85Ah@12V)
$2,099 AUD $2,499 AUD
EcoFlow DELTA 2 Max Solar Generator(PV400W)
$3,198 AUD $3,898 AUD
2kWh Capacity (167Ah@12V)
Fully Charge in as Fast as 2.6 hr
$2,549 AUD $3,298 -$749
Recommended by Media
by TechDay"In a world where the demand for sustainable and portable energy solutions is ever-increasing, the EcoFlow DELTA 2 Max stands out as a beacon of innovation and reliability."
by Trusted Reviews"...its excellent range of outputs and high efficiency make it a great choice for those that need a lot of power on the go."
by Digital Trends"In the Delta 2 Max, EcoFlow uses them to bring the second generation of its gold-standard power station to another level."
Power pretty much anything with up to 3100W output.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Power for Every Scenarios
2048Wh Capacity
A generous 2048Wh capacity makes DELTA 2 Max ideal for home backup, running your essentials for hours. With its lightweight design, DELTA 2 Max is portable enough to grab and go on the next camping trip.
*Data based on a 120W referigerator.
RVing & Outdoors
Professional Work
Filmmaking & Photography
*Fuel Up 80% in Only 43 Mins
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
10-year long-lasting LFP battery
Durable, Safe, Lightweight
Extensive 5-Year
Expandable up to 6kWh
Tripple the Power
Take control of your power
Save more on electricity billsCustomize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
*Weight 23kg
With LFP cells, DELTA 2 Max is safe, durable, and highly efficient, even in warm temperatures.
A rubber anti-slip base and a fire-resistant casing offer multiple layers of protection.
As Quiet as 30 dB
Peaceful charging.
*From a distance of approximately 20 in., noise level is 30 dB (with low input and 500W output) vs. other power stations with 55 dB or higher.
Field-Tested Performance of the DELTA 2 Max with the 800W Alternator Charger
Featured on CREEK TO COAST
DELTA 2 Max
DELTA 2 Max
AC Charging cable
AC Charging cable
User manual & warranty card
2048Wh (167Ah@12V)
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
220-240V~10A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
497 × 242 × 305 mm
Net weight (kg)
23 kg
Customer Reviews
Based on 1 review
100%
(1)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
I
Irma G.
Efficient follow up and service
I was apprehensive to buy on line given the amount of money involved; but given that it was the official ECOFlow shop I decided to give it a try. I did not place my residential address but postal address and the next day there was a follow up and correction of details. Then the expected day of delivery was delayed by a few days. Followed the tracking and whennthis came to a depot it stoped there. Contacted them by email and the product arrived at the same time. Then the registration of the warranty, I am too old to have too many apps so I called and was given instructions on how to do it without the app.
I am satisfied with the service and product. Thank you very much!
