EcoFlow RIVER 3 Portable Power Station | EcoFlow AU - RIVER 3 (20 ms UPS)
EcoFlow Australia
Regular price $369.00 AUD
Sale price $369.00 AUD Regular price $459.00
Save up to $90
  • 245Wh capacity (20.4Ah@12V) , 300W rated output, X-Boost up to 600W
  • Up to 2× runtime for light-wattage appliances
  • 30% smaller than the industry average
  • <10 ms UPS for uninterruptible backup
  • <30dB whisper quiet for 24/7 use
  • 1-hr fast charging, no battery damage
  • IP54 waterproof-rated battery pack
  • Charge up to 5 appliances at the same time
$369 AUD $459 -$90
An ideal starter battery that is compact yet delivers powerful performance.
Compact design, longer runtime
Easily handle power outages and extend outdoor stays with GaN
With groundbreaking X-GaNPower, RIVER 3(UPS) is changing the industry with compact, quiet batteries that deliver long runtimes for small electronics. By tapping into the superior energy efficiency of GaN, this series stretches the operating time of low-wattage devices while reducing the size and controlling the volume.
30% more compact for on-the-go use
RIVER 3 (UPS) minimises heat loss, requires less cooling space, and supports a compact design. It easily fits
into small spaces like closets, or a bag for easy storage and portability.
AC charging
Solar charging
Car charging
Generator charging
RIVER 3 (UPS) fast-charges in 1 hour with X-Stream, no battery damage with vehicle-grade cells and trickle charge technology.
Power up RIVER 3 (UPS) in only 2.6 hours with 110W solar input. Go even more portable with our 45W Portable Solar Panel (USB-C) and charge electronics directly.
Charge RIVER 3 (UPS) using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge it in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Power up to 600W appliances
Your reliable companion for outdoor adventures.
RIVER 3 (UPS) keeps 90% of your must-have appliances running with 300W of power. With X-Boost technology, it can power 600W heating devices without breaking a sweat. Keep your essentials running smoothly, even during power outages or outdoor getaways.
< 30 db whisper quiet for 24/7 backup
With X-GaNPower technology, the RIVER 3 (UPS) ensures lower energy loss and improved heat dissipation. Operating at a library-like silence level of less than 30 dB when measured from a distance of 0.15 m, it guarantees peace and quiet day and night.
Industry-Leading Intelligent Battery Protection
LiFePO4 Cells with a 10-Year Lifespan
The RIVER 3 (UPS) offers a lifespan of 3000 charging cycles—equivalent to approximately 10 years of daily use before its capacity drops to 80%.
X-Guard Battery Protection Technology
Equipped with an advanced algorithm for cloud-based battery monitoring and over 40 safety measures, the RIVER 3 (UPS) protects against risks related to current, voltage, temperature, and circuits.
With IP54-rated battery protection, water damage is minimised. Its robust fire-retardant shell withstands tough conditions, and even after a 1-meter fall, the RIVER 3 (UPS) remains undamaged.
Upgraded Smart Control
Convenient, Intelligent, and Customised Power
Product Details
What’s in the box
245Wh
255 x 212 x 113 mm
3.5kg
UPS
<10 ms
Noise
<30 dB
1 port, 230V~50Hz, 300W total (Surge 600W, X-Boost 600W)
2 ports, 5V, 2.4A, 12W Max per port, total 24W
1 port, 5/9/12/15⎓3A Max, 20V⎓5A Max,100W Max
Car Output
1 port, 12.6V, 10A,126W Max
AC Input
300W, 0-100% in 60 min
Solar Input
110W, 0-100% in as fast as 2.6 hr
Car Input
100W, 11~30V, 0-100% in 2.8 hr
