A$1,329.00
Dual-zone flexibility*
The dual-zone design (45L & 55L only) lets you store fresh and frozen food simultaneously with a maximum temperature difference of 22°C. Advanced sensors maintain precise conditions (±1°C) to keep food perfectly fresh.
* The 35L model features single-zone cooling, switchable between fridge and freezer modes.
40%* more compact design, giving you more space in your car—a true home on the move. The EcoFlow GLACIER Classic maximizes storage efficiency, fitting 58 cans (35L), 72 cans (45L), and 90 cans (55L) of 330ml soda while staying sleek and space-saving.
* Based on laboratory testing data, the external dimension is 40% smaller than that of standard electric coolers.
298Wh plug-in battery (Sold separately)
The EcoFlow GLACIER Classic keeps your items chilled at 4°C for up to 43 hours (35L) or 39 hours (45L and 55L)**
* The EcoFlow GLACIER Plug-in Battery is sold separately.
** Tested at 25°C ambient temperature with a fully charged battery.
Max Mode
Eco Mode
Temperature Alert
Get notified if the internal temperature deviates by over 5°C for 10+ minutes, keeping items like meat and dairy safe.
Temperature History
Multiple charging options
* For optimal performance, use the plug-in battery to avoid unstable power due to inconsistent sunlight. The EcoFlow GLACIER Plug-in Battery is sold separately.* Compatible with EcoFlow 500W and 800W Alternator Chargers.
Doubles as a power bank
Dimensions- external
706×400×405 mm / 27.8×15.8×15.9 in
Dimensions- internal
487×284×298.5 mm / 19×11×11.7 in
20.5 kg
Usable Volume
35L
Number of 330ml Cans
58 cans
Temperature Zone
Variable Dual Temperature
AC Input
AC Adapter: 95W max,14.5V; 100-240V 50/60Hz
DC Input
Solar Charging: 11-30V, 8A/110W max
Battery Runtime
43 hr(Tested @ Ambient temperature: 25°C/77°F, Eco mode)
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C) ~ (20°C)
(-10°C) ~ (50°C)
Storage Temperature
(-20°C) ~ (60°C)
Temperature Accuracy
Eco mode: ±2~3°C; Max mode: ±1°C
Refrigeration(4°C): 165wh/24h; 0.57 Ah/h
Freezing (-18°C): 520wh/24h; 1.8 Ah/h
(Tested @ Ambient temperature: 25°C, Eco mode)
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
What's in the Box
1. EcoFlow AC Power Adapter
2. Basket
3. EcoFlow Car Charging Cable
706×400×480 mm / 27.8×15.8×18.9 in
487×284×373.5 mm / 19×11×14.7 in
23.2 kg
Usable Volume
45L
72 cans
Temperature Zone
Dual Temperature Zone
AC Input
DC Input
Battery Runtime
39 hr
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C) ~ (20°C)
*The left and right temperature zones support a 22°C temperature difference
(-10°C) ~ (50°C)
Storage Temperature
(-20°C) ~ (60°C)
Refrigeration(4°C): 190wh/24h; 0.67 Ah/h
Freezing (-18°C): 750wh/24h; 2.6 Ah/h
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
What's in the Box
2. Basket
4. Temperature Zone Divider
706×466×480 mm / 27.8×18.4×18.9 in
487×350×373.5 mm / 19×13.8×14.7 in
25.2 kg/55.6 lb
Usable Volume
55L
90 cans
Temperature Zone
AC Input
DC Input
Battery Runtime
39 hr(Tested @ Ambient temperature: 25°C, Eco mode)
Rated Power
55W
Noise
< 38.5 dB
Protection Level
IPX4
(-20°C) ~ (20°C)
(-10°C/14°F) ~ (50°C/122°F)
Storage Temperature
(-20°C) ~ (60°C)
Max mode: ±1°C/1.8°F
Refrigeration(4°C): 190Wh/24h;0.67 Ah/h
Freezing (-18°C): 750Wh/24h;2.6 Ah/h
App
Suppported
2 Years(ES 3 Years)
Refrigerant
R600a
What's in the Box
2. Basket
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
