EcoFlow Australia
EcoFlow RIVER 3 Max Plus Portable Power Station (858Wh)
A$1,179.00
Regular price A$1,179.00
Sale price A$1,179.00 Regular price A$1,399.00
Save up to A$220
- 858Wh , 600W rated output and 1200W X-Boost
- Up to 2× runtime for light-wattage appliances
- Compact and lightweight
- 2.3 hr charge, no battery damage
- Up to 220W fast solar charging
- <30 dB whisper quiet for 24/7 use
A$1,179 A$1,399 -A$220
Top-performing home backup power with a pro-grade UPS solution
Your reliable companion through outages or in the wild.
Up to 600W output
RIVER 3 Max Plus is a beast in the small power station game, cranking out up to 600W of rated power. Its X-Boost
technology can continuously handle 1200W heating devices without breaking a sweat, keeping 90% of
home appliances running smoothly. With an additional built-in light, you'll never get left in the dark.
<10 ms pro-grade auto-switch
Seamless home office and gaming experience
The RIVER 3 Max Plus provides premium protection with a <10 ms switchover, safeguarding sensitive equipment
for home office and gaming experiences against sudden power loss
Comprehensive UPS solution
Safeguard for work andplay
Equipped with a 858Wh capacity and 600W output, RIVER 3 Max Plus can power a 3W Wi-Fi router for up to 86.9 hours. Plus, it can run pretty much any office appliance, including 600W computers for at least 60 minutes, allowing a safe shutdown and completion of ongoing tasks.
Smart outage alert
Stay alert during power outages with the RIVER 3 Max Plus, equipped with an LED,app, and software alerts. Its PC and NAS-compatible data interface, along with the EcoFlow software, notifies you and automatically saves data for you when the battery is low.
UPS-friendly design
With two rear AC outlets, conceal your device cables. Plus, monitor UPS in real time on the upgraded screen.
RIVER 3 Max Plus vs Traditional UPS
2× light and network runtime
Easily handle power outages and extend outdoor stays
With its groundbreaking X-GaNPower technology, the RIVER 3 Max Plus is revolutionizing the industry with
compact, quiet batteries that offer extended runtimes for small electronics. Leveraging the superior energy
efficiency of GaN, the RIVER 3 Max Plus doubles the operating time of appliances under 100W, delivering twice the runtime
Extremely compact and lightweight
Handy, convenient on-the-go power
RIVER 3 Max Plus minimizes heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, a minivan, or a bag for easy storage and portability.
< 30 db whisper quietfor 24/7 backup
Quiet backup for peace day and night
With X-GanPower technology, from enhanced heat dissipation, RIVER 3 Max Plus operates on a library-like
silence level, with a volume of less than 30 dB at a distance of 1.5 ft.² You'll have peace day and night
guaranteed, even when it's running nonstop.
Expandable up to 858Wh with a wire-free connection
Level up your power with RIVER 3 Plus with an Extra Battery. RIVER 3 Plus can handle either the EB300 (286Wh) or the EB600 (572Wh), Just stack them to get up to 858Wh of pure energy.
Hassle-free connection
Utilizing Pogo Pin tech, the batteries connect wirelessly, fastening easily with clips instead of cables or screws.
Adds an extra charging and recharging option
Add an extra battery to your RIVER 3 Max Plus for 140W USB-C charging and recharging, plus the freedom to use it on its own.³
AC charging
Solar charging
Car charging
Generator charging
RIVER 3 Max Plus fast-charges in 1.8 hrs with X-Stream, no battery damage with vehicle-grade cells and trickle charge technology.
Power up RIVER 3 Max Plus in only 4.8 hours with 220W solar input. Go even more portable with our 45W Portable Solar Panel (USB-C) and charge electronics directly.
Charge RIVER 3 Max Plus using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge it in just 1.8 hrs with a gas generator for a full day of quiet, safe, and efficient power.
Industry-leading intelligent battery protection
RIVER 3 Max Plus has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 Max Plus protects against various current, voltage, temperature, and circuit risks.
With IP54 battery protection, water damage is minimized4. Its robust fire-retardant shell survives rough conditions. Even after a 1m fall, the RIVER 3 Max Plus won't get damaged.
Upgraded smart control
Convenient, intelligent, customized power control
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
What’s in the box
RIVER 3 Plus
RIVER 3 Max
RIVER 3 Max Plus
RIVER 3 Plus Specs
286Wh
234x232x146mm
4.7kg
UPS
<10ms
Noise
<30dB
2 ports, 5V=2.4A, 12W Max per port, total 24W
1 port, 5/9/12/15=3A Max, 20V=5A Max, 100W Max
Car Output
AC Input
360W Max, 0-100% in 1 hr
Solar Input
220W Max, 0-100% in as fast as 1.5 hr
Car Input
220W, 0-100% in 3.3 hr
Generator Input
Optimal Operating Temperature
20°C-30°C
Charge Temperature
0°C-45°C
Discharge Temperature
-10°C-45°C
Storage Temperature
20°C-30°C
RIVER 3 Max Specs
572Wh
234 x 232 x 238mm
8.4kg
UPS
<10ms
Noise
<30dB
Car Output
AC Input
650W 0~100% in 1.3 Hr
Solar Input
220W, 0-100% in 3.2 hr
Car Input
220W 0-100% in 7.2 hr
Generator Input
20°C-30°C
Charge Temperature
0°C-45°C
-10°C-45°C
Storage Temperature
20°C-30°C
RIVER 3 Max Plus Specs
858Wh
234x232×286mm
10.8kg
UPS
<10ms
Noise
<30dB
