EcoFlow Australia
D
H
M
S
A$109.00
Regular price A$109.00
Sale price A$109.00 Regular price A$109.00
  • Qi2 15W Wireless Charging: Enjoy the ease of 15W wireless charging, which is two times faster than Qi1 7.5W charging and backed by Qi2 certification, ensuring quick, safe, and effective energy top-ups.
  • Ultra-Fast Charging with 30W Built-in Cable: With a 30W built-in cable, you don't need to bring extra cables with you for ultra-fast charging. Enjoy magnetic ease with maximum charging speed wherever you go.
  • Flash Recharging: With 30W input, charge from 0% to 70% in under 33 minutes while you get ready to head out.
  • Compact and Streamlined Design: Experience our compact, lightweight power bank. Small yet mighty, it charges your iPhone 15 Pro 1.1 times. Perfect for life on the go—stay connected always.
  • Built-in Stand for Versatile Use: The kickstand for upright or side view offers hands-free use, doubling as a desktop stand.
Color
Silver
Blue
EcoFlow RAPID Magnetic Power Bank (10000mAh)
A$159
Qi2 15W Wireless Charge
Max 65W Input & Output
A$159
A$109
X-Stream
Flash charge and recharge with RAPID power
RAPID uses patented X-Stream technology for flagship smartphone-level energy density and fast charging capability. Plus, it works with the PD3.0 protocol for flash charging and recharging. Paired with Qi2-certified wireless charging and a built-in cable design, RAPID ensures snap-on charging convenience with maximum charging speeds.
Qi2-certificated wireless charging that's twice as fast
Max-speed charging with built-in cable
The ultimate fast-recharging power bank
Rely on RAPID for power on the go
With a high output power and multiple charging protocol compatibility, RAPID charges most portable devices, including Macbooks, iPads, Kindles, fitness bands, and earbuds.
Remote Work
On-the-go
Socializing
Give your 13-inch MacBook Air a boost with RAPID 10000mAh for an extra 4 hours of power「5」.
Perfect as a travel charging hub for your iPhone, AirPods, and other essentials, as well as recharging itself at the same time.
Share power with your friends and charge two phones simultaneously.
Built-in stand and strong magnetic connection
Kickstand for upright/side view
Anti-slip Magnetism
1. Place it vertically on a desk, to use your phone as a digital clock or make video calls.
2. Lay it horizontally to comfortably watch movies.
With N52 magnets for a powerful bond and anti-slip components, the power bank and the phone connect smoothly. The power bank holds firmly in place without sliding when the phone is in use.
Exclusive structure maintains a low temp
Using advanced car-grade ultra-low internal resistance technology, along with special internal cooling system, we significantly reduced overheating issues of magnetic charging.
Temperature sensor for real-time monitoring, 4.32 million times per day
RAPID's temperature sensor monitors the power bank 50 times per second, that's more than 4 million daily checks to prevent the power bank from overheating.
Two-year worry-free use
Color
Silver
5000mAh
Ports
C1: Type- C built in cable (input/output)
C2: Type-C Ports (input/output)
Wired Charging Input
30W
Recharging Time
33min-70% 59min-100%
Wired Charging Output
30W
Wireless Charging Output
Qi2.0 15W
Wireless Charging Time
42min - iPhone15 Pro to 50%
Bluetooth
No
Digital Display
No
APP
No
108mm*70mm*14.4mm/4.25*2.76*0.57 inch
Weight
180g/6.35oz
