EcoFlow Australia
D
H
M
S
EcoFlow RAPID Magnetic Power Bank (10000mAh)
Regular price A$159.00
Sale price A$159.00 Regular price A$159.00
  • Qi2 15W Wireless Charging: Enjoy the ease of 15W wireless charging, which is two times faster than Qi1 7.5W charging and backed by Qi2 certification, ensuring quick, safe, and effective energy top-ups.
  • Ultra-Fast Charging with 65W Built-in Cable: You don't need to bring an extra cable with you for ultra-fast charging and can give your 13-inch MacBook Air an urgent boost for an extra 8 hours of power.
  • Flash Recharging: With 30W input, charge from 0% to 70% in under 33 minutes while you get ready to head out.
  • Smart Digital Display: Experience ultimate control with our power bank's dynamic screen. Using smart app control, you can view charging speed, power output, and add a personal touch by customizing your screen.
  • Built-in Stand for Versatile Use: The kickstand for upright or side view offers hands-free use, doubling as a desktop stand.
  • Intelligent App Control: Besides viewing more detailed charging insights you could also turn on "Healthy Charging Mode" to protect your battery for longer battery life and find your power bank via the embeddeed buzzer if you misplace it.
Color
Silver
Type
A$159
EcoFlow integrates cutting-edge battery and software technology into everyday portable use with RAPID, the new magnetic charging experience.
X-Stream
Flash charge and recharge with RAPID power
RAPID uses patented X-Stream technology for flagship smartphone-level energy density and fast charging capability. Plus, it works with the PD3.0 protocol for flash charging and recharging. Paired with Qi2-certified wireless charging and a built-in cable design, RAPID ensures snap-on charging convenience with maximum charging speeds.
Qi2-certificated wireless charging that's twice as fast
Max-speed charging with built-in cable
The ultimate fast-recharging power bank
Rely on RAPID for power on the go
With a high output power and multiple charging protocol compatibility, RAPID charges most portable devices, including Macbooks, iPads, Kindles, fitness bands, and earbuds.
Remote Work
On-the-go
Give your 13-inch MacBook Air a boost with RAPID 10000mAh for an extra 4 hours of power「5」.
Perfect as a travel charging hub for your iPhone, AirPods, and other essentials, as well as recharging itself at the same time.
Stay informated with a smart digital display
The TFT display lets you view battery capacity, output and time to recharge, so you're always informed and in control of your power.
Customize your display
Personalize your RAPID power bank boot screen display with your name or favorite DIY pattern or name using the EcoFlow app.
Intelligent control using the EcoFlow app
Built-in stand and strong magnetic connection
Kickstand for upright/side view
Anti-slip Magnetism
1. Place it vertically on a desk, to use your phone as a digital clock or make video calls.
2. Lay it horizontally to comfortably watch movies.
With N52 magnets for a powerful bond and anti-slip components, the power bank and the phone connect smoothly. The power bank holds firmly in place without sliding when the phone is in use.
Exclusive structure maintains a low temp
Using advanced car-grade ultra-low internal resistance technology, along with special internal cooling system, we significantly reduced overheating issues of magnetic charging.
Temperature sensor for real-time monitoring, 4.32 million times per day
RAPID's temperature sensor monitors the power bank 50 times per second, that's more than 4 million daily checks to prevent the power bank from overheating.
Two-year worry-free use
Color
Silver
10000mAh
Ports
C1: Type- C built in cable (input/output)
C2: Type-C Ports (input/output)
Type C Charging Input
65W
Built in Cable Charging Input
60W
Recharging Time
33min-70% 59min-100%
Wired Charging Output
65W
Wireless Charging Output
Qi2.0 15W
Wireless Charging Time
42min - iPhone15 Pro to 50%
Bluetooth
Yes
Digital Display
Yes
APP
Yes
108mm*70mm*22.9mm/4.25*2.76*0.9 inch
Weight
258g/9.1oz
