Buy EcoFlow NextGen 160W Single-facial Solar Panel - 160W Single-facial Portable Solar Panel
EcoFlow Australia
Regular price $499.00 AUD
Sale price $499.00 AUD Regular price $499.00
-25% High Solar Conversion Efficiency:Maximize energy capture even in limited sunlight. -Easy setup for Optimal Output: Integrates with a 30–60° adjustable angle bracket and integrated solar angle guide to easily align with the sun.
-Rugged & Reliable in Any Environment: Durable ETFE coating and IP68 water and dust resistance ensure long-term outdoor performance.
-Ultra-Portable Design: Lightweight, compact, and easy to carry—ideal for off-grid adventures.
-Ready Out of the Box: Includes solar to XT60 charging cable for seamless connection with EcoFlow portable power stations.
Style
Accessories
$499 AUD
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Integrated solar angle guide
Keeps sunlight at a 90° angle on the surface of your solar panel to capture the most energy possible.
Durable and waterproof
Built to weather the storm
With an IP68 waterproof rating, our NextGen 160W Solar Panel maintains its high performance even in extreme weather conditions, including rainfall. It's dust-resistant, too.
Never too hot
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
EcoFlow Solar Panel Comparison
Original vs. NextGen
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Solar Panel
EcoFlow Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
160W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 12.3 lb (5.6 kg)
Unfolded: 23.6×63.4×1.0 in./600×1610×25 mm Folded: 23.6×22.5×1.3 in./600×572×32 mm
Connector Type
Photovoltaic connectors
Warranty (US)
12 months
Open Circuit Voltage
21.3V (Vmp 18.6V)
Short Circuit Current
9.1A (Imp 8.6A)
Waterproof & Dustproof
