A$5,099.00
Weekend Flash Sale🔥 Shop Now >
Start an energy-saving lifestyle without the need for electrical work. With the DELTA Pro 3, you can create a home energy storage system without a grid connection, cutting down on installation costs. Store solar energy in the DELTA Pro 3 during the day and use it at night to power your household appliances, saving approximately 22% on daily energy consumption with just one unit. Add an extra battery to save 44%, and two extra batteries to save up to 66% per day.
Charge Up, Fast, and Everywhere
Introducing EcoFlow's groundbreaking X-Stream fast charging technology, setting a new industry standard. Charge from 0 to 80% in just 1 hr. With multi-charge combinations, enjoy up to 7000W of super-fast charging.
Effortless All-in-One Command with the EcoFlow App
Effortless Portability and Space-Efficient
Portable design for an ideal lifestyle. Boosts portability with its wide wheels, ergonomic handle, and compact design. Its magnetic sliding doors simplify access, optimising space and power for mobility without compromise. Ideal for dynamic lifestyles and maximising family space.
Equipped with a portable home battery, ensuring peace of mind in emergencies.
Equipped with a TT30 port to power RVs.
Achieve off-grid capability with solar panels and the DELTA Pro 3.
With powerful output and expandable capacity, it's ideal for various high-power appliances.
Quiet Comfort for Your Home and Neighbors
It's whisper-quiet with X-Quiet technology, ensuring a peaceful hum*, promising you a night of peaceful sleep even if you keep it beside your bed. It's so silent that you'll hardly notice it's there.
*as low as 30 dB, thanks to our X-Quiet tech
What's In The Box?
4096Wh
5 outlets, 4000W max. (Surge 8000W)
X-Boost 6000W, Supports up to two DELTA Pro 3 Smart Extra Batteries
DC Output
7 Outlet
2x USB-A, 5V 2.4A 9V 2A 12V 1.5A 18W Max
2xUSB-C, 5/9/12/15/20V 5A 100W Max.
1×DC5521,5AMax
1xAnderson,30A Max
1x Remote Control Port
Solar Charging Input
2600W
Connection
Wi-Fi 2.4GHz/Bluetooth
693×341×410 mm
Car Charging Input
12V 8A max.
48V 20A max.
51.5 kg (113.54 lb)
EcoFlow DELTA Pro 3 has two PV input ports, which are for high-voltage PV port and low-voltage PV, respectively.High-voltage PV: 30-150V, 15A Max, 1600W Max. Low-voltage PV: 11-60V, 20A Max, 1000W Max.
Yes, it will.However, there are specific requirements for the light conditions. In weak lighting environments, it might not trigger the device to power on.
4000 cycles.After undergoing 4000 cycles at a rate of 0.5C/0.5C at 25°C (77°F), the battery maintains over 80% of its state of health (SoH).
Optimal operating temperature: 20°C-30°CCharging temperature range: 0℃-45℃Discharge temperature range: –10℃-45℃Recommended long-term storage temperature: 20℃-30℃
As the core component of the device, the safety and protection level of the battery pack is crucial. To better protect the battery pack and reduce the risk of short circuits and fires caused by water ingress, the EcoFlow DELTA Pro 3 battery pack is sealed. It has reached an IP65 waterproof and dustproof rating, effectively preventing dust from entering and resisting water spray.However, the EcoFlow DELTA Pro 3 main unit does not have a waterproof and dustproof rating (IP20). The device is suitable for use in well-ventilated indoor environments or sheltered outdoor environments to avoid the impact of rain and dust on the device. Please ensure that the surrounding environment is dry and clean during installation and use to ensure the device's normal operation and longevity.
EcoFlow DELTA Pro 3 is equipped with an internal GFCI ground circuit. Users can connect an external GFCI protector according to their needs. When an external GFCI protector is connected to EcoFlow DELTA Pro 3, the GFCI support switch must be turned on in the app for the external GFCI protector to function properly.
Yes, supported. Please note that all devices need to be upgraded to the latest firmware version to ensure compatibility.
No, not supported.
Supported. However, due to the different capacities of the EcoFlow DELTA Pro Extra Battery and the EcoFlow DELTA Pro 3 Extra Battery, there will be some SOC imbalance.
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
