EcoFlow DELTA 3 Ultra Plus Portable Power Station | EcoFlow AU - DELTA 3 Ultra Plus + 800W Alternator Charger
EcoFlow Australia
A$3,399.00
Regular price A$3,399.00
Sale price A$3,399.00 Regular price A$4,399.00
Save up to A$1,000
Early Bird Offer—Buy Bundle, get FREE Power Bank
- 3600W AC output, X-Boost 4700W, 7200W surge output,
- 3–11kWh expandable capacity
- 5 fast recharging methods: AC, Solar, Alternator Charger, Generator, and Multi-charging
- <10 ms UPS Auto-Switch
* Paired with Alternator Charger to reach 1000W input, DELTA 3 Ultra Plus use the Smart Generator Adapter or EcoFlow 1000W Alternator Charger Cable (Included free in bundle)
Bundle Options
A$3,399 A$4,399 -A$1,000
3600W Output, 7200W Surge—Powerful. Stable. Built to Handle It All
DELTA 3 Ultra Plus (3072Wh) delivers 3600W rated-output (7200W surge) , with X-Boost™ 3.0 technology, it supports devices up to 4700W—effortlessly handling heavy-duty appliances. The inverter samples AC voltage and current every 33μs with high precision with a DSP chip, ensuring a pure sine wave output with beyond grid-level stability—ideal for powering sensitive electronics reliably.
Kitchen
Living Room
Laundry Room
Office
RV Camping
Garage
Easily Scales Up—From Hours to Days
*Multiple appliances' backup time based on ideal conditions; actual results may vary.
Half-Day Outage
1-Day Outage
2-Day Outage
3-Day Outage
Covers essential power needs during a 4-10 hour outage-keeping food fresh, heat running, lights on, and communication devices charged.
Delivers 1 days of outage protection—ensuring uninterrupted cooking, heating, lighting, and connectivity.
* Require connecting 1 × DELTA 3 Ultra Plus + 1 × DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. EcoFlow Extra Battery Expansion Adapter — sold separately.
Powers home essentials for up to 2 days with 7kWh capacity-keeping your kitchen running, lights on,and devices connected.
*Require connecting 1 × DELTA 3 Ultra Plus + 2 × DELTA 3 Max Plus Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter. EcoFlow Extra Battery Expansion Adapter — sold separately.
Supports a family of four through 3 days of everyday living with11kWh capacity-keeping food fresh, heat running, lights on, and entertainment devices charged.
*Require connecting 1 × DELTA 3 Ultra Plus + 2 × DELTA Pro 3 Smart Extra Battery with EcoFlow Smart Extra Battery Expansion Adapter.EcoFlow Extra Battery Expansion Adapter — sold separately.
Ways to Charge Up — Ready in Just 75 Mins [1]
0-80% in 75 minutes was measured in optimal conditions using X-Stream AC charging. Actual user experience may vary.
5 Ways to Charge Up — Ready in Just 75 Mins
Wall/AC Charging
Alternator Charging
Solar + Alternator Dual Charging
Generator Charging
2300W Input, 0-80% in 75 mins. [1] EcoFlow’s exclusive Storm Guard Mode [3] monitors severe weather alerts and automatically triggers AC charging remotely using industry-leading X-Stream fast charging tech—so it can be ready long before a disaster hits.
1600W input, 0–80% in 101 mins.Pair it with EcoFlow 400W Solar Panels (25% high-efficiency) for reliable power during camping trips, van life, or off-grid living. [4]
1000W Input, 0-80% in 142 mins. With EcoFlow Alternator Charger Plus 1000 [5], get ready in just over 2 hours while on the move—10× faster than conventional solutions. [6]
*To use the Alternator Charger Plus 1000, DELTA 3 Ultra Plus must use the Smart Generator Adapter. Buy bundle, get Smart Generator Adapter for free.
2600W Input, 0-80% in 60 mins. Dual input from 1600W solar and 1000W alternator charging keeps you powered faster than ever, even on the go.
Up to 2400W max input, with compatibility with third-party generators.
Built to Last
From battery chemistry to structural design, DELTA 3 Ultra Plus (3072Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years. [2]
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Built to Last
Battery Protection
CTC Structure
Durable Qualities
Class B Certified
25dB [8]
EcoFlow’s advanced BMS uses a high-performance ARM Cortex chipset and intelligent algorithms to monitor your battery in real time. By tracking SOC, SOH, temperature, and more, it ensures peak performance, extended battery life, and worry-free operation.
Built with a cell-to-chassis (CTC) structure, DELTA 3 Ultra Plus (3072Wh) is drop-resistant (0.2m) —protecting against overnight condensation and off-road bumps during transport. You get stable power even in the most demanding conditions. [7]
DELTA 3 Ultra Plus (3072Wh) keeps your power flowing through freezing cold, scorching heat, humid environments (95% humidity tolerance), or coastal air (5% salt spray resistance). [7]
Certified to Class B EMC standards, it won’t interfere with TVs, Wi-Fi, or other home electronics.
Powered by X-Quiet™ 3.0, EcoFlow’s stepless fan control adjusts airflow smoothly to maintain precise thermal regulation—keeping your home or workspace peacefully quiet, even under heavy loads.
Deeper Insights, Easier Control [3]
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings.
Compatiblity
* To reach 1000W input, DELTA 3 Ultra Plus / DELTA 3 Max Plus / DELTA Pro 3 / DELTA Pro must use the Smart Generator Adapter.
*Buy bundle, get Smart Generator Adapter for free.
Battery
3072Wh (256Ah @12V)
Nunber of Extra Battery Port
1, expandable to 2
Type of Extra Battery Port
4+8
Max Capacity with Extra Battery
Up to 11kWh with 2*DELTA Pro 3 EB
Output
Max AC Output
3600W
AC Outlets Number
4
Output Voltage
230V~50Hz 3600W total, 15A(x4) Max per port
Surge Output
7200W
Max Output by X-Boost
4700W
Number of DC Outlets
5
USB-A
1×18W Max
USB-C
USB-C(x2): 5/9V/12V/15V-3A 20V-2.25A, 45W Max per port, (total 45W)
12V DC Output
Total 378W MaxCar Charging Output*1, 12.6V⎓10AAnderson Output*1, 12.6V⎓ 30A
Input
Utility Power Charging
2300W
Input Voltage
220-240V~10A 50/60Hz
0-80% Charge time
75min
0-100% Charge time
110min
Solar charging
1600W Max
Generator charging
2400W Max
Alternator Charging
1000W Max, through 4+8 Port
Car charging
12/24V , 8A
General
UPS
<10ms
613.1×327.7×395.0mm
Net weight (kg)
Approx. 33.7kg
Connectivity
Wi-Fi & Bluetooth
5-Year Warranty *Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
What’s in the box
[1] 0-80% in 75 minutes was measured in optimal conditions using X-Stream AC charging. Actual user experience may vary.
[2] Based on proper product usage, DELTA 3 Ultra Plus (3072Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
[3] App features may vary by region. For detailed instructions, please contact customer support.
[4] EcoFlow Solar Panels are sold separately.
[5] EcoFlow Alternator Charger Plus 1000 is sold separately.
[6] Compared with car cigarette port charging. Data measured under ideal conditions; actual results may vary.
[7] Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[8] Noise levels measured at 1m under 25°C ambient: ≤25dB (600W) for charging/discharging.
[9] Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
[10] A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
