EcoFlow DELTA 3 Max Plus Portable Power Station+400W Solar Panel
A$3,999.00
Real Power, No Compromise
* DELTA 3 Max Plus features a global-standard Powerpole Anderson port. For applications requiring an SB50 interface, a Powerpole-to-SB50 adapter is required. Please feel free to contact EcoFlow customer support at +61 1800610238/support.au@ecoflow.com for compatibility guidance and recommended solutions.
25% More Power: 3000W Output, 2kWh Capacity
*25% More Power: Compared with EcoFlow DELTA 2 Max.
Introduce industry-first Smart Output Priority Tech. Users can take manual remote control of two AC circuits and one DC circuit, or let the Plus models automatically follow the pre-set priority. For example, when the battery capacity reaches the pre-set 50% threshold, the Plus models automatically switch off non-critical loads like lights while critical appliances like the fridge remain powered.
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings
Powered by X-Quiet 3.0, EcoFlow's stepless fan control adjusts airflow smoothly to maintain precise thermal regulation-keeping your home or workspace peacefully quiet, even under heavy loads.* Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
Fastest-in-class UPS, keeping your devices running smoothly—whether at home, in the garage, or on the move. Reliable energy that works seamlessly with your daily life.
From battery chemistry to structural design, DELTA 3 Max Plus is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.
Ultra-Powerful, Lightweight 2kWh Portable Power. Flexible Options Across All Kinds of Needs
* To reach 1000W input, DELTA 3 Max Plus / DELTA Pro 3 / DELTA Pro must use the Smart Generator Adapter. Otherwise, input is limited to a maximum of 500W. DELTA 2/DELTA 3/ DELTA 3 Plus/DELTA 3 1500 support 1000W input directly.
*Buy bundle, get Smart Generator Adapter for free.
2048Wh
Max AC Output
3000W
Max Output by X-Boost
3900W
Surge Output
6000W
Total Output Ports
10
Number of AC Outlets
4
12V DC Output
Anderson Output: 1 port, 12.6V⎓30A
Car Power Output: 1 port, 12.6V⎓10A
USB-A
1 × 18W Max
USB-C
1 × 140W Max(HID); 2 × 45W Max(Total 45W)
Solar Input
1000W (2*500W)
AC Input
2300W (68 min)
Car Charging
12V/24V⎓8A
Alternator Charging
DELTA 3 Max Plus - 1000W Max (Through 4+8 Port)
Generator Charging
2400W Max
UPS
<10 ms
Noise
600W <25 dB
Extra Battery Ports
4+8 Port, expandable to 2
5 Years
Approx. 22.1 kg
494 × 242 × 305 mm
APP/Bluetooth/Wi-Fi
Yes
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
