EcoFlow DELTA 3 Classic Portable Power Station | EcoFlow AU - DELTA 3 Classic Solar Generator (PV400W)
EcoFlow Australia
A$2,259.00
Regular price A$2,259.00
Sale price A$2,259.00 Regular price A$2,498.00
Save up to A$239
Best-Value 1 kWh Portable Power Station
1800W Powerful Output: 3600W surge output. With X-Boost™ tech, supports high-demand devices up to 2400W such as portable fridges, camping kettles, laptops, and power tools.
- Ready in Just 45 Mins: Charges from 0–80% in just 45 minutes with AC charging.
Lightweight, Compact, Portable: Fits seamlessly into outdoor, mobile, and professional setups.
Bundle Options
A$2,259 A$2,498 -A$239
EcoFlow’s Best-Value 1 kWh Portable Power Station
Smart choice for your outdoor adventures and work
1800W Output, 3600W Surge
Power Essentials Without Compromise
EcoFlow DELTA 3 Classic delivers a steady1800W pure sine wave outputwith grid-level stability—built to handle demanding outdoor and professional equipment with confidence. [2] With X-Boost™ mode, it supports devices up to 2400W without tripping or slowing down—giving you seamless power for the moments that matter.
Camping
Outdoor Filming
Outdoor Work
3 Ways to Charge——Ready As Fast As in 45 Mins
DELTA 3 Classic (1024Wh) charges from 0–80% in just 45 minutes with AC charging. It keeps you powered faster, smarter, and with greater peace of mind—whether outdoors or on the move.
AC Charging
Car Charging
Fully charged in 2.5 hours with 500W solar input. Clean, renewable energy—wherever the sun shines.
Charge to 80% in 1.8 hours or 100% in 2.5 hours using the EcoFlow 500W Alternator Charger. [5]
Compact, Portable — Works Anywhere You Go
Lightweight and easy to carry, DELTA 3 Classic fits seamlessly into outdoor, mobile, and professional setups. Take it with you for camping, field work, filming, or any situation where reliable portable power is essential.
Fast Emergency Power Switching. No Interruptions.
When the power source changes, DELTA 3 Classic responds in as fast as 10 milliseconds—helping maintain continuous operation for critical outdoor and professional equipment. Designed to reduce interruptions during power transitions, it supports stable performance for sensitive devices in mobile and field environments.
10-Year Lifespan, Built to Last
From battery chemistry to structural design, DELTA 3 Classic (1024Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.[1]
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
Choose the Product That Suits You Best
Battery
1024Wh (85Ah @12V)
Nunber of Extra Battery Port
No
Max Capacity with Extra Battery
No
Output
Output Voltage
230V
Max AC Output
1800W
AC Outlets Number
3
Surge Output
3600W
Max Output by X-Boost
2400W
USB-A-Fast
1*12W
USB-C
1*100W +1*30W
12V DC Output
No
Input
AC Charging
1400W (60 mins)
Solar charging
500W Max
Generator charging
1400W
Alternator Charging
500W
Car charging
No
General
UPS
<10ms
398*200*283mm
Net weight (kg)
12.1kg+0.3kg
Connectivity
Wi-Fi & Bluetooth
3+2 years (Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration)
What’s in the box
1. Based on proper product usage, DELTA 3 Classic is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
2. Single-appliance runtime based on ideal conditions; actual results may vary.
3. All Charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
4. Feature requires preset activation via the EcoFlow App.
5. EcoFlow 500W Alternator Charger is sold separately.
6. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
7. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
8. Compared with the previous usage of EF #C33 Battery Cell.
9. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
10. Noise levels measured at 0.5m under 25°C ambient: <30dB (600W) for charging/discharging.
11. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
