EcoFlow DELTA 3 Classic Portable Power Station
A$899.00
Smart choice for your outdoor adventures and work
Lightweight and easy to carry, DELTA 3 Classic fits seamlessly into outdoor, mobile, and professional setups. Take it with you for camping, field work, filming, or any situation where reliable portable power is essential.
When the power source changes, DELTA 3 Classic responds in as fast as 10 milliseconds—helping maintain continuous operation for critical outdoor and professional equipment. Designed to reduce interruptions during power transitions, it supports stable performance for sensitive devices in mobile and field environments.
From battery chemistry to structural design, DELTA 3 Classic (1024Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.[1]
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
1. Based on proper product usage, DELTA 3 Classic is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
2. Single-appliance runtime based on ideal conditions; actual results may vary.
3. All Charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
4. Feature requires preset activation via the EcoFlow App.
5. EcoFlow 500W Alternator Charger is sold separately.
6. Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
7. A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
8. Compared with the previous usage of EF #C33 Battery Cell.
9. Unless otherwise noted, all above data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
10. Noise levels measured at 0.5m under 25°C ambient: <30dB (600W) for charging/discharging.
11. Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
