EcoFlow DELTA 2 Max + 800W Alternator Charger
A$3,139.00
Weekend Flash Sale🔥 Shop Now >
With the EcoFlow 800W Alternator Charger, charge 8 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
*Alternator capacity varies by vehicle - please verify with your manualternator's output supports the alternator charger's maximum power draw for safe operation.
Conveniently adapts to 12V/24V RV house batteries.Connects to EcoFlow portable power stations and protects RV house batteries while expanding energy storage capacity by up to 7.2kWh*.
*With EcoFlow DELTA Pro and DELTA Pro Extra Battery
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time.The 800W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
DELTA Pro
Capacity: 3600Wh
Charging Time (By XT150 Port): 4.8 hours
DELTA 2 Max
Capacity: 2048Wh
Charging Time (By XT150 Port): 2.6 hours
DELTA Max 2000
Capacity: 2016Wh
DELTA 2
Capacity: 1024Wh
Charging Time (By XT150 Port): 1.3 hours
DELTA 2 EB
Capacity: 1024Wh
DELTA 2 Max EB
Capacity: 2048Wh
DELTA 3 Plus
Capacity: 1024Wh
DELTA 3 1500
Capacity: 1536Wh
Charging Time (By XT150 Port): 2.0 hours
DELTA Pro 3
Capacity: 4096Wh
Charging Time (By XT150 Port): 5.4 hours
Featured on CREEK TO COAST
Model
EF-FC-301-1
2.3 kg
Dimensions (W × D × H)
242×194×35 mm
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: <20dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: <10dBm
Charging Mode
Input: 11V-31V, 76A Max.
Output: 40V-60V, 800W Max.
Battery Maintenance Mode
Input: 40V-60V, 3A Max.
Reverse Charging Mode
Input: 40V-60V, 21A Max.
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage protection
Undervoltage protection
Operating Temperature
–20℃ to 60℃
Storage Temperature
–30℃ to 70℃
Operating Humidity
≤95%
Storage Humidity
≤95%
No, the 800W alternator charger's charging logic does not rigidly apply 800 watts. Instead, it depends on the power surplus of the car's alternator. It ensures the alternator is not overloaded, allowing up to a maximum of 800 watts without harming the car's battery.
Terms and Conditions:
¹The 800W refers to the speed under full power charging. The charging power is related to the car generator's current and operating condition.
*Note: EcoCredits are redeemable for gifts and discounts
Your preferences are saved.
We’ll personalize your experience from here.
