EcoFlow On-the-Road Power Solution | EcoFlow AU - DELTA 2 Max 1900 + 800W Alternator Charger
EcoFlow Australia
D
H
M
S
Regular price A$599.00
Sale price A$599.00 Regular price A$599.00
  • 800W(70A@12V*) input, 1.3 hrs to fully charge 1kWh (85Ah@12V)
  • FREE Energy with Every Minute Driving
  • 3-in-1 Fast Charger, Maintainer, and Battery Booster
*Please note that if you need to connect the 800W Alternator Charger to the DELTA Pro, you will need to purchase the DELTA Pro to Smart Generator Adapter separately. Alternatively, you can opt for the DP+800W bundle, which already includes the Adapter, so there's no need to buy it separately.
A$349 A$499
500W(45A@12V*) input, 2.1 hrs to fully charge 1kWh (85Ah@12V)
A$599
Top up 1kWh in only 1.3 hours
With the EcoFlow 800W Alternator Charger, charge 8 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
*Alternator capacity varies by vehicle - please verify with your manualternator's output supports the alternator charger's maximum power draw for safe operation.
How to Choose your EcoFlow Alternator Charger
*Not compatible with discontinued models: DELTA 1300, DELTA 1600, DELTA Mini, DELTA Max.
More Detailed Specifications for 500W & 800W Alternator Charger
The 3-in-1 charger, maintainer, and jump starter saves time, money, and precious in-vehicle space.
With its smart and efficient fast charging capabilities, you'll stay powered no matter how long you're on the road.
Charging Mode
Reverse Charging Mode
Battery Maintenance Mode
Extend your RV house battery runtime
Conveniently adapts to 12V/24V RV house batteries.Connects to EcoFlow portable power stations and protects RV house batteries while expanding energy storage capacity by up to 7.2kWh*.
*With EcoFlow DELTA Pro and DELTA Pro Extra Battery
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time.The 800W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Connect your 800W Alternator Charger to your vehicle's starter battery or RV's house battery to enjoy a worry-free power experience during your journey.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Connect the fuse cable to the input cable on one end.
Connect the fuse cable to the vehicle battery on the other end.
Connect the black cable to the chassis terminal.
Thread the other end of the input cable through the car body towards the charger. If the input cable is bulky or difficult to pull through, disconnect the cable ends before threading.
Plug the other side of the input cable into the EcoFlow 800W Alternator Charger.
Plug in the output cable from the EcoFlow 800W Alternator Charger to the portable power station.
Compatible with EcoFlow Portable Power Stations
DELTA Pro
Capacity: 3600Wh
Charging Time (By XT150 Port): 4.8 hours
DELTA 2 Max
Capacity: 2048Wh
Charging Time (By XT150 Port): 2.6 hours
DELTA Max 2000
Capacity: 2016Wh
DELTA 2
Capacity: 1024Wh
Charging Time (By XT150 Port): 1.3 hours
DELTA 2 EB
Capacity: 1024Wh
DELTA 2 Max EB
Capacity: 2048Wh
DELTA 3 Plus
Capacity: 1024Wh
DELTA 3 1500
Capacity: 1536Wh
Charging Time (By XT150 Port): 2.0 hours
DELTA Pro 3
Capacity: 4096Wh
Charging Time (By XT150 Port): 5.4 hours
Field-Tested Performance of the DELTA 2 Max with the 800W Alternator Charger
Featured on CREEK TO COAST
Model
EF-FC-301-1
2.3 kg
Dimensions (W × D × H)
242×194×35 mm
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: <20dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: <10dBm
Charging Mode
Input: 11V-31V, 76A Max.
Output: 40V-60V, 800W Max.
Input: 40V-60V, 3A Max.
Input: 40V-60V, 21A Max.
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage protection
Undervoltage protection
Operating Temperature
–20℃ to 60℃
Storage Temperature
–30℃ to 70℃
Operating Humidity
≤95%
Storage Humidity
≤95%
Will this product damage the alternator, starter battery, or affect the overall lifespan of the vehicle?
No, the 800W alternator charger's charging logic does not rigidly apply 800 watts. Instead, it depends on the power surplus of the car's alternator. It ensures the alternator is not overloaded, allowing up to a maximum of 800 watts without harming the car's battery.
Will this product consume more fuel (i.e. affect gas mileage) when used?
Is this product suitable for DIY installation?
Is it normal for the alternator charger to get hot?
How long does it take to fully charge a DELTA Series product?
Compared to charging via the cigarette lighter, what advantages does the alternator charger offer when used in a vehicle?
Solution to the problem that the EcoFlow WAVE 2 add-on battery does not work with the alternator charger.
How can I tell if the alternator charger is applicable to my car?
What protections are in place for the alternator charger in a car?
How many operation modes are there for the alternator charger?
What does the indicator light on the alternator charger mean?
How does the alternator charger automatically start and stop?
What type of vehicles are suitable for installation? Do they all reach the maximum charging power of the alternator charger?
What is the overall size of the alternator charger?
What is the input of the alternator charger?
What is the output of the alternator charger?
What are the operating and storage temperatures of the alternator charger?
Will installing an alternator charger affect my car's warranty?
Terms and Conditions:
¹The 800W refers to the speed under full power charging. The charging power is related to the car generator's current and operating condition.
