Ideal solar power source for RIVER Series
With its compact design and lightweight, a 45W portable solar panel is the ideal companion for RIVER Series power stations, providing a simple and convenient charging experience.
Designed for Type-C charging
Charge your gadgets directly
45W Portable Solar Panel (Type-C) includes a Type-C output port to direct charge devices like phones, laptops, and air pumps. Experience the utmost convenience with our 45W Portable Solar Panel (Type-C).
*The output of the Type-C port is up to maximum 15W.
Up to 25% conversion rate
Charge faster with an even smaller panel.
With the introduction of TOPCon solar technology, a first in the mini portable solar panel industry, we've set a new standard for conversion efficiency, achieving 25%. This enables faster charging in a more compact form. Fully charge RIVER 2 in 7 hours during peak sunlight hours, and power your electronics and essential camping appliances for a longer adventure.
More benefits of adopting TOPCon
EcoFlow 45W Solar Panel with TOPCon vs traditional solar panel with PERC material
Extremely compact
Easily fit into any compact space
With its folding four-panel structure,the portable solar panel significantly reduces in size when folded, allowing it to easily fit into compact spaces such as backpacks, SUVs, or minivans.
IP68 Waterproof, built to last
Always be ready for unexpected weather
Featuring robust PCB fiberglass and a durable ETFE coating, our panels are designed to withstand
challenging weather conditions. Whether it's a sudden impact, being pulled by the wind, or even exposure to salty ocean spray and water droplets, they remain undamaged and strong, serving as your reliable outdoor companion.*
Designed for hanging
Charging on the go
In addition to being laid flat on the ground or tilted using a stand, the 45W portable solar panel can be hung using the four pre-cut eyelets and hooks included. Whether hung on your car or backpack, save time by charging while you're heading to your next destination.
Product details
Rated Power
45W
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
Up to 25%
Open Circuit Voltage
25.6V
Short Circuit Current
2.06A
Weight (Solar Panel)
1.4 kg
Unfolded Dimensions
980×309×25 mm
Folded Dimensions
222×309×45 mm
Waterproof Certification
