EcoFlow Australia
D
H
M
S
EcoFlow 160W Lightweight Portable Solar Panel
Regular price A$499.00
Sale price A$499.00 Regular price A$569.00
Save up to A$70
-Lightweight and portable
-Up to 25% conversion efficiency rate with a bifacial design
-Built-in XT60 cable for easy storage and connection to power stations
-30-60° adjustable support stand and integrated solar angle guide
-IP68 rating protects against water and dust
-5-Year Warranty
Type
A$499 A$569 -A$70
Ultra-Portable Design
Engineered with advanced lightweight materials, this next-gen solar panel weighs 3.8 kg (1.8 kg lighter than previous models) for effortless transport and compact storage.
Capture More Energy with a Bifacial Design
With a primary panel and rear-side panel for ambient light, output power reaches up to 177W under BNPI test conditions, generating more power from the same amount of sunlight compared to traditional monofacial panels. With industry-leading TOPCon solar technology, this portable solar panel achieves a top-level conversion rate of up to 25%, recharging your power station even faster.
Built-in XT60
The integrated XT60 cable makes it easy to store and seamless to connect to portable power stations for a faster setup.
Built-in XT60
Built-in XT60
Built-in XT60
Built-in XT60
Built-in XT60
Built-in XT60
Suitable for Various Environments
The folding integrated bracket offers a convenient and compact design. Adjustable from 30°-60°, it's ideal even for most high-latitude areas.
* If you need to hang solar panels for extended periods, please use rigid solar panels. Lightweight portable solar panels are not recommended for this scenario.
Integrated Solar Angle Guide
Keep sunlight at a 90° angle and concentrate the sun's rays onto the surface of your solar panel to get the most light at all times.
Durable and Water-Resistant
Built to Weather the Storm
With an IP68 water-resistance rating, our 160W Lightweight Portable Solar Panel maintains its high performance even when in contact with water, so you can safely recharge in wet conditions, such as seaside or on a boat.
No Overheating
Designed to withstand high temperatures while still ensuring high levels of solar generation.
5-Year Warranty
What’s in the box
Rated Power
STC 160W(±5W) / BNPI 177W(±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25%
Weight (Solar Panel)
3.8kg±0.3kg
1677mm*598mm*26mm
Folded: 609mm*598mm*26mm
Connector Type
XT60
Built-in cable length: 8.20 feet
5 Years
Open Circuit Voltage
21.4V(Vmp: 18.8V)
Short Circuit Current
STC 9.2A(Imp: 8.7A)
BNPI 10.2A(Imp: 9.6A)
Waterproof & Dustproof
What type of solar cells are used in this panel?
182.2 mm*183.75 mm N-type TOPCon cell
Which EcoFlow portable power stations are compatible with the EcoFlow 160W Lightweight Portable Solar Panel?
The solar panel has an XT60 connection cable, and the maximum output voltage is 21.4V. When using the solar panel with EcoFlow portable power stations, we recommend making sure that the solar panel's output current (voltage) should be lower than the portable power station's input current (voltage).
Are this solar panel and all its connection points fully waterproof?
This solar panel has an IP68 rating and boasts outstanding waterproof performance. However, we recommend against extended exposure to moist environments, as this may reduce the device's lifespan.
What ports does the solar panel have?
This lightweight solar panel has an XT60 output port. It can be used to connect to EcoFlow portable power stations directly without the need for an adapter.
What are the optimal operating voltage (Vmp) and current (Imp) for this solar panel?
The optimal operating voltage is 18.8V, and the optimal operating current is 8.7A.
Should this solar panel be connected using serial or parallel connections? How can I get the necessary accessories?
It is recommended to connect this solar panel to panels of the same model using a serial connection and use it together with EcoFlow portable power stations. When connected using a parallel connection, the current would be too high to adapt properly to the portable power station, so this setup is not recommended. The serial connection cables need to be purchased separately.
Can this solar panel be connected to an extension cable?
No extension cable currently available to purchase can be used together with this solar panel.
