EcoFlow Australia
D
H
M
S
Regular price A$4,119.00
Sale price A$4,119.00 Regular price A$5,299.00
Save up to A$1,180
• Recharge your RV and EV anytime, anywhere
Number of Solar Panel
A$4,119 A$5,299 -A$1,180
A$549 A$599
800W(70A@12V*) input, 1.3 hrs to fully charge 1kWh (85Ah@12V)
EcoFlow DELTA Pro Remote Control
A$169
EcoFlow Smart Generator Adapter
A$139
Introducing the world's first portable home battery with an expandable ecosystem for home backup, smart energy management, lower energy bills, and more. The EcoFlow DELTA Pro is the next leap in portable power technology, offering you power security and independence, wherever you are.
Expandable Capacity
Power Pretty Much Anything (3600W-7200W Output)
World's Fastest Charging (MultiCharge 6500W)
Home Integration
What's in the box - DELTA Pro
1.DELTA Pro 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.Handle Cover 6.User Manual
What's in the Box - 400W Solar Panel
1. 400W Solar Panel 2. Kickstand Case 3. User Manual
When charging DELTA Pro and its extra battery together, you can reach 6500W max charging speeds by combining AC, solar and Smart Generator methods. For DELTA Pro single unit, you can recharge it at standard wall outlets (2900W max), at EV station (3400W max)/Smart Home Panel (3000W max).
It depends on the combined voltage and current of the solar panels you choose. It's fine as long as the solar panels use MC4 connectors and their combined voltage and current are within 11-150 volts and under 15 amps.
First of all, make sure your DELTA Pro is connected to the EcoFlow App using Internet mode. Secondly, go to the Firmware section in the Setting of the DELTA Pro you're looking to upgrade. Check for the latest firmware and follow the steps to finish the upgrade.
Specs of DELTA Pro
Approx. 99lbs/45kg
Dimension
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2300W Max, 230V~10A eb
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth, wired
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.40%
41.7*93.1*1.0 in (105.8*236.5*2.4cm)
Connector Type
MC4
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 27.6lbs (12.5Kg)
Weight (with Kickstand Case)
34.2lbs / 15.5kg
