EcoFlow Australia
D
H
M
S
EcoFlow DELTA Pro Remote Control
Regular price A$169.00
Sale price A$169.00 Regular price A$169.00
The first of its kind: The first remote control for a portable power station, designed for DELTA Pro. Ideal for storing your DELTA Pro in the garage, storage bay, or below deck. Connect over Bluetooth or an ethernet cable and get a second screen right where you need it.
Monitor your energy: The display shows how much energy you’re using, the remaining battery time, and everything else DELTA Pro’s screen shows. It’s also a convenient place to turn on/off the AC outlets, DC outlets, or entire unit.
Two ways to connect: Move the screen around when connected with Bluetooth; set it and forget it with a wired connection that works over longer distances.
Control at a distance: Once set up, you can monitor & control your portable power station from afar. Ideal when your DELTA Pro is set up with solar panels, or at a charger.
Note: This accessory is only compatible with the EcoFlow DELTA Pro.
A$169
DELTA Pro Smart Extra Battery
A$3,499
Extra 3kWh for DELTA Pro
EcoFlow Smart Generator Adapter
A$139
