DELTA Pro Portable Power Station | EcoFlow AU
EcoFlow Australia
A$2,999.00
Sale Ends in
Days
Hours
Minutes
Seconds
Regular price A$2,999.00
Sale price A$2,999.00 Regular price A$4,499.00
Save up to A$1,500
*DELTA Pro requires the EcoFlow Alternator Charger Cable to use the 800W Alternator Charger. (Included free with this bundle)
  • 3.6-25kWh expandable capacity (300Ah@12V)
  • Recharge your RV and EV anytime, anywhere
A$2,999 A$4,499 -A$1,500
A$549 A$599
800W(70A@12V*) input, 1.3 hrs to fully charge 1kWh (85Ah@12V)
DELTA Pro Smart Extra Battery
A$2,699 A$3,499
Extra 3kWh for DELTA Pro
EcoFlow EV X-Stream Adapter (DELTA Pro)
A$169
Power for any situation.
DELTA Pro,Powering 150,000+homes in over 120 countries
as a state-of-art high-capacity power station.
DELTA Pro, the Prime
Choice of 150k
Worldwide Homes
Incredible Power and Effortless Portability design
DELTA Pro,Powering 150,000+homes in over 120 countries<br> as a state-of-art high-capacity power station. DELTA Pro,Powering 150,000+homes in over 120 countries<br> as a state-of-art high-capacity power station.
Runs 99% of All Household Appliances
Whether you're powering heavy-duty devices at home, outdoors, or in your workplace, DELTA Pro's 3600W AC output handles it all with ease.
Rapid 2-Hour Charging
Multicharge at an impressive 6500W rate, and you'll be back up and running in just 2 hours.
Versatile Portability
With its convenient wheels and retractable handle, taking DELTA Pro on the go becomes a breeze. It's perfect for camping, RVing and even outdoor events.
5-Year Warranty Assurance
Enjoy one of the longest warranties in the industry, ensuring your continued use and peace of mind for years to come.
All the AC output you'll need.
A single DELTA Pro unit packs a 3600W AC output, which can be expanded up to 4500W with X-Boost technology. Power 99.99% heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W with Smart Home Panel.
The world's fastest charging portable power station.
Fully charge in 1.9 hours.
EcoFlow's X-Stream charging technology isn't just fast, it's safe too. The battery management system ensures safety and longevity while you fully charge DELTA Pro from a standard AC wall outlet in 1.9 hours*.
Charge up at thousands of EV stations worldwide.
For the first time ever with a portable power station, you can charge up at thousands of EV stations worldwide. This unique charging method gives you up to 3400W fast charging on the go.
Go renewable with 1600W solar charging.
EcoFlow's suite of solar products give you a cost-effective renewable energy source to stay powered. You can use solar energy to charge DELTA Pro in just 2.8-5.6 hours. DELTA Pro has a wide voltage range from 11-150V, which makes it compatible with 90% of third-party solar panels with MC4 connectors. And when the weather gets unpredictable, the smart maximum power point tracking (MPPT) automatically adjusts, maximizing your solar generation at any time of the day.
Get emergency backup power with the EcoFlow Smart Generator.
The EcoFlow Smart Generator serves as an emergency option that integrates with your DELTA Pro ecosystem. It auto-starts when your DELTA Pro hits a low level of charge, re-charges your DELTA Pro, and stops the engine all by itself once your DELTA Pro hits a full charge. Compared to a traditional gas generator, the EcoFlow Smart Generator delivers less energy loss, faster charging and higher efficiency.
DELTA Pro sports a brand-new LFP battery with 6500 cycles, which means you can use DELTA Pro for years and years before your unit reaches 50% of the original capacity. EcoFlow's battery management system provides real-time analysis and regulation of voltage, current, and temperature. This unique protection mechanism makes DELTA Pro an incredibly safe and efficient home battery.
Multiple ways to control & monitor.
Control DELTA Pro either on the unit itself, using the remote control accessory, or unlock a ton of customization via the EcoFlow app. On the app, you can access your power settings, such as charging and discharging levels, AC charge speeds, control the Smart Generator and a whole lot more.
The world's first portable home battery ecosystem.
DELTA Pro's expandable ecosystem provides you with power during blackouts, customizable energy around the clock, and lower energy bills. How does it achieve all this? With a selection of extra batteries, smart generators, solar trackers, wind turbines, a smart home panel, and more. From backup power to reducing your reliance on the grid with green alternatives, the DELTA Pro ecosystem can be customized to your needs.
Introducing the EcoFlow Smart Home Panel.
The new EcoFlow Smart Home Panel is the heart of the DELTA Pro home battery ecosystem. It integrates up to two DELTA Pro units with 10 home circuits. Each DELTA Pro can be connected with extra batteries, solar panels, or smart generators, giving you uninterrupted power during blackouts, smart energy management for your critical loads, and lower energy bills.
Uninterrupted home backup.
With a fast 20ms switchover time, DELTA Pro and the Smart Home Panel can keep you powered on during a blackout. All the while, the EcoFlow app keeps you in the know, letting you select and modify your device priorities.
Smart Energy Management.
The EcoFlow DELTA Pro ecosystem stores energy day and night, reducing your reliance on the grid and lowering your energy bills by combating time-of-use rates. It integrates directly with your home using the EcoFlow Smart Home Panel. The EcoFlow app gives you a smart breakdown of your energy habits, and you can customize your energy usage for any type of situation.
RV living made easy.
With DELTA Pro, you can take home with you, wherever you go. It features wheels and a suitcase-esque extendable handle that makes transport easy.
Power that means business.
Not only does DELTA Pro provide home backup and off-grid power, it also gives you a secure power source for any type of professional work. Whether you're working at home or outdoors, from DIY to professional projects, DELTA Pro helps you get the job done.
What's In The Box
1.DELTA Pro 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.Handle Cover 6.User Manual
Approx. 45kg
Dimension
63.5*28.4*42cm
3600Wh (300Ah@12V)
Extra Battery
4 outlets, 230V/10A, 3600W total (Surge 7200W)
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
2300W Max, 230V~10A
Solar Charging Input
1600W Max, 11-150V, 15A
Car Charging Input
Support 12V/24V battery, 8A
Cycle life
Connection
Wi-Fi, Bluetooth
