DELTA 3 Max Plus Portable Power Station | EcoFlow AU - DELTA 3 Max Plus Solar Generator (PV220W)
EcoFlow Australia
EcoFlow DELTA 3 Max Plus Solar Generator (PV220W)
A$3,009.00
Sale Ends in
Days
Hours
Minutes
Seconds
Regular price A$3,009.00
Sale price A$3,009.00 Regular price A$3,699.00
Save up to A$690
- 3000W AC output, X-Boost 3900W, 6000W surge output,
- industry-first Smart Output Priority Tech.
- 5 fast recharging methods: AC, Solar, Alternator Charger, Smart Generator, and Multi-charging
- <10 ms UPS Auto-Switch
* Paired with Alternator Charger to reach 1000W input, DELTA 3 Max Plus use the Smart Generator Adapter. (Included free in bundle)
Bundle Options
A$3,009 A$3,699 -A$690
EcoFlow DELTA 3 Max Plus (2048Wh)
Real Power, No Compromise
* DELTA 3 Max Plus features a global-standard Powerpole Anderson port. For applications requiring an SB50 interface, a Powerpole-to-SB50 adapter is required. Please feel free to contact EcoFlow customer support at +61 1800610238/support.au@ecoflow.com for compatibility guidance and recommended solutions.
3000W Max Professional Power for Everywhere
25% More Power: 3000W Output, 2kWh Capacity
*25% More Power: Compared with EcoFlow DELTA 2 Max.
Real Power to Explore Everywhere
Outdoor Camping
RV Motorhome
Job Site
Garden & Backyard Homesteading
DELTA 3 Max Plus delivers 3000W AC rated output (6000W surge). With X-Boost™ 3.0 technology, it supports devices up to 3900W—effortlessly taking on your heavy-duty appliances.
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
*When paired with the Alternator Charger Plus 1000, a Smart Generator Adapter is required to achieve 1000W input.
* The Smart Generator Adapter is included free of charge when purchased as a bundle
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
*A Custom Fit Output Cable is required for 800W input and is included free with the bundle.
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
5 Ways to Charge Up
Wall/AC Charging
Alternator+Solar Dual Charging
Alternator Charging
Generator Charging
Industry-leading 2300W max AC charging input, 0-80% as fast as in 47 mins.
*0-80% in 47 minutes was measured in optimal conditions using X-Stream AC charging.
Charge on the go with EcoFlow's new Alternator Charger Plus 1000. Featuring dual input—300W solar+700W alternator—ensuring faster, more efficient charging even on the go.
EcoFlow’s 500W, 800W, and Alternator Charger Plus 1000 deliver up to 10× faster charging than a standard car cigarette lighter.
Up to 1000W solar input, class-leading solar charging that gets you solar-ready within 2 hours.
Up to 2400W max input, with compatibility with third-party generators.
Pick Your Priority Outputs, Extend What Matters Most
Introduce industry-first Smart Output Priority Tech. Users can take manual remote control of two AC circuits and one DC circuit, or let the Plus models automatically follow the pre-set priority. For example, when the battery capacity reaches the pre-set 50% threshold, the Plus models automatically switch off non-critical loads like lights while critical appliances like the fridge remain powered.
Energy Management Made Simple, Smarter Insights to Help You Save
Monitor your energy usage, savings, and solar generation—all with one intuitive dashboard. Easily track battery status, real-time electricity rates, and financial savings
25dB Whisper-Quiet Operation under loads
Powered by X-Quiet 3.0, EcoFlow's stepless fan control adjusts airflow smoothly to maintain precise thermal regulation-keeping your home or workspace peacefully quiet, even under heavy loads.* Noise levels measured at 0.5m under 25°C ambient: ≤25dB (600W) for charging/discharging.
10ms Auto Switch, Uninterrupted Power
Fastest-in-class UPS, keeping your devices running smoothly—whether at home, in the garage, or on the move. Reliable energy that works seamlessly with your daily life.
2–10kWh expandable capacity
*Multiple appliances' backup time based on ideal conditions; actual results may vary.
2-10kWh Expandable Capacity
Half-Day Outage
1-Day Power Usage
2-Day Power Usage
3-Day Power Usage
Covers essential power needs during a 4–8 hour outage—keeping food fresh, heat running, lights on, and communication devices charged.
Delivers 1 day of outage protection—ensuring uninterrupted cooking, heating, lighting, and connectivity.
Powers home essentials for up to 2 days with 6kWh capacity—keeping your kitchen running, lights on, and devices connected.
Supports a family of four through 3 days of everyday living with 10kWh capacity—keeping food fresh, heat running, lights on, and entertainment devices charged.
Built to Last
From battery chemistry to structural design, DELTA 3 Max Plus is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.
Why EcoFlow DELTA Max Series Stands Out?
Ultra-Powerful, Lightweight 2kWh Portable Power. Flexible Options Across All Kinds of Needs
Compatiblity
* To reach 1000W input, DELTA 3 Max Plus / DELTA Pro 3 / DELTA Pro must use the Smart Generator Adapter. Otherwise, input is limited to a maximum of 500W. DELTA 2/DELTA 3/ DELTA 3 Plus/DELTA 3 1500 support 1000W input directly.
*Buy bundle, get Smart Generator Adapter for free. (Ship in Mid-May)
What’s in the box
DELTA 3 Max Plus Specs
2048Wh
Max AC Output
3000W
Max Output by X-Boost
3900W
Surge Output
6000W
Total Output Ports
10
Number of AC Outlets
4
12V DC Output
Anderson Output: 1 port, 12.6V⎓30A
Car Power Output: 1 port, 12.6V⎓10A
USB-A
1 × 18W Max
USB-C
1 × 140W Max(HID); 2 × 45W Max(Total 45W)
Solar Input
1000W (2*500W)
AC Input
2300W (68 min)
Car Charging
12V/24V⎓8A
Alternator Charging
DELTA 3 Max Plus - 1000W Max (Through 4+8 Port)
Generator Charging
2400W Max
UPS
<10 ms
Noise
600W <25 dB
Extra Battery Ports
4+8 Port, expandable to 2
5 Years
Approx. 22.1 kg
494 × 242 × 305 mm
APP/Bluetooth/Wi-Fi
Yes
