EcoFlow RIVER 2 Pro Solar Generator (PV160W) | EcoFlow Australia - Default Title - EcoFlow Australia
EcoFlow Australia
EcoFlow RIVER 2 Pro Solar Generator (Single-facial PV160W) -Get a Camping Light for free (Limited Stock)
Regular price $1,298.00 AUD
Sale price $1,298.00 AUD Regular price $1,898.00
Save up to $600
⏰Spring Sale Ends In
Days
Hours
Minutes
Seconds
• With 768Wh capacity and 160W solar input, the solar generator can produce up to 1.8kWh daily.
• A 800W AC output
• Charge 0-100% in only 70 mins with AC input.
• Up to 23% conversion to guarantee a fast solar charging speed: 0-100% in 5 hours (1 set).
• LiFePO4 battery and IP68 dust and water resistance.
• Lightweight, travel-friendly, and great for home backup.
• Smart remote control with EcoFlow app.
• 5-year warranty for RIVER 2 Pro and 24-month warranty for 160W Portable Solar Panel.
$1,298 AUD $1,898 -$600
EcoFlow RIVER 2 Pro Solar Generator (Bi-facial PV220W)
$1,698 AUD $2,098 AUD
Solar charging: 0-100% in 4.5 hours (1 set)
EcoFlow Solar Extension Cable
$39.90 AUD
Power. Never Been This Easy
Charge 0-100% in 70 mins
Fastest charging speeds ever.
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes. That's 5x faster than other portable power stations on the market and 27% quicker than previous generations. Fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use1 and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there's a recharge option no matter what. From fast AC to in-car charging when you're on the go.
AC ChargingCar ChargingSolar ChargingUSB-C Charging
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
X-Boost Up to 1600W
Small size. Big power.
RIVER 2 Pro has an AC output of up to 800W. Need to power a hair dryer, microwave or electric kettle? Crank it up to 1600W with X-Boost mode to run up to 80% of high-wattage home appliances.
Lightweight at only 7.8 kg
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 Series as an emergency power supply for overnight outages to keep essentials running from a light to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Power. Anywhere. Anytime.
1. RIVER 2 Pro2. AC Charging Cable3. Car Charging Cable4. DC5521 Connection Cable5. Quick Start Guide6. 160W Solar Panel7. Solar Charging Cable
*The solar charging cable is sent together with the solar panel.
768Wh
Approximately 7.8kg
270 x 260 x 226mm
AC Input
220-240V~ 50Hz/60Hz, 940W Max
Solar Input
11-50V 13A, 220W Max
USB-C Input/Output
5/9/12/15/20V 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
Pure Sine Wave, 800W total (surge 1600W), 230V ~ 50Hz/60Hz
Cell Chemistry
Discharge Temperature
-10°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)
Car Input
12V/24V, 8A, 100W Max
DC5521 Output
12.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
