Buy EcoFlow NextGen 220W Portable Solar Panel(Single-facial ) - 220W Single-facial Solar Panel
EcoFlow Australia
EcoFlow NextGen 220W Portable Solar Panel (Single-facial)
Regular price $459.00 AUD
Sale price $459.00 AUD Regular price $629.00
Save up to $170
-Ultra-Light & Portable: Single panel weighs just 7kg+, making it easy to carry, set up, and store.
-Versatile Applications: Ideal for home backup, off-grid cabins, and outdoor adventures alike.
-25% Solar Efficiency: Captures sunlight from both sides for up to 25% more energy
-All-Day Energy from One Panel: A full day of sun can cover your daily outdoor power needs.
Type
Accessories
$459 AUD $629 -$170
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Integrated solar angle guide
Keeps sunlight at a 90° angle on the surface of your solar panel to capture the most energy possible.
Durable and waterproof
Built to weather the storm
With an IP68 waterproof rating, our NextGen 220W Solar Panel maintains its high performance even in extreme weather conditions, including rainfall. It's dust-resistant, too.
Never too hot
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
EcoFlow Solar Panel Comparison
Original vs. NextGen
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Solar Panel
EcoFlow Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
220W (±5W)
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 15.9 lb (7.2 kg)
Unfolded: 23.6×83.6×1.0 in./600×2123×25 mm
Folded: 23.6×22.5×1.3 in./600 x 571×32 mm
Connector Type
Photovoltaic connectors
Warranty (US)
12 months
Open Circuit Voltage
21.5V (Vmp 18.4V)
Short Circuit Current
12.4A (Imp 11.9A)
Waterproof & Dustproof
