DELTA 2 Max Portable Power Station | EcoFlow AU - DELTA 2 Max + 500W Alternator Charger
EcoFlow Australia
$3,098.00 AUD
Regular price $3,098.00 AUD
Sale price $3,098.00 AUD Regular price $3,098.00
Expandable capacity: 2-6kWh expandable capacity (167Ah@12V) to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit 6144Wh. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That's down to its LFP battery chemistry giving you 3000 cycles.
Huge AC output: With X-Boost mode, get up to 3300W output power to run 99% of home appliances. Power 13 devices at once, including 4 AC outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours
Capture more energy: 99% MPPT efficiency maximises solar generation during the daytime.
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty:24+36 (Registration for warranty extension)
Bundle Options
EcoFlow DELTA 2 Max Bag
$159 AUD
$2,099 AUD $2,499 AUD
$599 AUD
800W(70A@12V*) input, 1.3 hrs to fully charge 1kWh (85Ah@12V)
$159 AUD
$599 AUD
$159 AUD
$599 AUD
$159 AUD
$599 AUD
$3,098 AUD
Recommended by Media
by TechDay"In a world where the demand for sustainable and portable energy solutions is ever-increasing, the EcoFlow DELTA 2 Max stands out as a beacon of innovation and reliability."
by Trusted Reviews"...its excellent range of outputs and high efficiency make it a great choice for those that need a lot of power on the go."
by Digital Trends"In the Delta 2 Max, EcoFlow uses them to bring the second generation of its gold-standard power station to another level."
Power pretty much anything with up to 3100W output.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Power for Every Scenarios
2048Wh Capacity
A generous 2048Wh capacity makes DELTA 2 Max ideal for home backup, running your essentials for hours. With its lightweight design, DELTA 2 Max is portable enough to grab and go on the next camping trip.
*Data based on a 120W referigerator.
RVing & Outdoors
Professional Work
Filmmaking & Photography
*Fuel Up 80% in Only 43 Mins
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
10-year long-lasting LFP battery
Durable, Safe, Lightweight
Extensive 5-Year
Expandable up to 6kWh
Tripple the Power
Take control of your power
Save more on electricity billsCustomize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
*Weight 23kg
With LFP cells, DELTA 2 Max is safe, durable, and highly efficient, even in warm temperatures.
A rubber anti-slip base and a fire-resistant casing offer multiple layers of protection.
As Quiet as 30 dB
Peaceful charging.
*From a distance of approximately 20 in., noise level is 30 dB (with low input and 500W output) vs. other power stations with 55 dB or higher.
Field-Tested Performance of the DELTA 2 Max with the 800W Alternator Charger
Featured on CREEK TO COAST
DELTA 2 Max
DELTA 2 Max
AC Charging cable
AC Charging cable
Car charging cable
Car charging cable
DC5521 to DC5525 Cable
User manual & warranty card
2048Wh (167Ah@12V)
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
220-240V~10A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
497 × 242 × 305 mm
Net weight (kg)
23 kg
Customer Reviews
Based on 42 reviews
90%
(38)
7%
(3)
2%
(1)
0%
(0)
0%
(0)
J
John A.
Delta 2 max, inverter & panels
Haven’t used any of the gear yet apart from topping up the charge on the delta 2 which seemed nice and quick. The app is very good and adds another level of control, all in all so far very happy. Arrived quite quickly by courier and post
J
Jodie M.
Delta 2 pro max
Great battery I was hoping for 3 full days for my fridge in van. But got 2 days. Quiet and easy to use.
M
Melanie W.
Delta 2 Max + 400W Panel = Perfect Off-Grid Combo
Absolutely satisfied with our Delta 2 Max and 400W solar panel. The panel charges fast even in deep winter, and the Delta 2 Max has become the heart of our off-grid system. We’re running it alongside our older solar setup, and it integrates beautifully. Reliable, powerful, and easy to use — this combo exceeded our expectations!
V
Vasilios K.
Ecoflow Batteries
Got 7 in total, 2x delta 2 pros with extra batteries, 1x delta 2 max, 1x delta 2 and 1x river 2 max. Also got a ev x-stream adaptor for the pros. Been running my home now on these for 3mths, and they haven't missed a beat. Charging units from grid because i get a 3hr window of free kwh. Thanks Ecoflow, great products, also customer service is top notch.
G
Geoff M.
Delta 2 max Gm
Great battery capacity and can effortlessly power 2400W household devices.
The unit is on the gefty side but is pluggable.
The bundle was great value combined with the 220W bifacial solar panel.
Beware, the adaptor cable is easy to miss in the bottom of the solar panel box.
