EcoFlow 400W Rigid Solar Panel - EcoFlow Australia
EcoFlow Australia
Grab the Best Deals of the Year! Stay Tuned!
D
H
M
S
Regular price $1,199.00 AUD
Sale price $1,199.00 AUD Regular price $1,599.00
Save up to $400
• Fast and Easy Installation
• Up to a 10-year warranty
EcoFlow Balcony Hook Kit
$59 AUD
$1,199 AUD $1,599 -$400
High Solar Energy Conversion
Made from highly efficient monocrystalline cells, the 400W rigid solar panel has an excellent efficiency rating of 23%, allowing you to charge faster than using similar-sized panels. Combine this panel as part of your existing PV system or Power Kits setup, and allow the integrated MPPT algorithm to optimize your solar input.
Waterproof & Durable
The 400W rigid solar panel is designed for the outdoors. With an IP68* waterproof rating and a robust anti-corrosive aluminum frame, the panel can withstand a wind speed of up to 130mph* and a significant snow load of up to 113lb* and continue to capture solar energy for years to come.
*Well-mounted solar panels can withstand a dynamic 2400pa wind pressure load (130mph wind speed) and a static 5400pa snow load (113lb per sq foot of snow).
Off-grid & On-grid Solution
This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible
EcoFlow solar panels use an all-inclusive solar connector, so you can even use them with your existing 48V power system. The 400W solar panel includes a 300mm charging cable that gives you plenty of space to mount multiple panels, maximizing solar input.
What's in the box?
1. 2×400W Rigid Solar Panel
2. User Manual and Warranty Card
3. Solar to XT60 Charging Cable
Installation Guide
Short Circuit Current
13.79A
Open Circuit Voltage
37.10V
Connector Type
Solar Connector
Efficiency
23%
Cell Type
Monocrystalline
Rated Power
400W
Maximum Operating Voltage
31.00V
Maximum Operating Current
12.90A
-0.38%/°C
-0.35%/°C
0.06%/°C
Maximum Fuse Current
25A
Maximum System Voltage
1500V DC (UL)
Dimension (inch)
67.8×44.6×1.38
Net Weight (kg)
21.8kg
Dimension (cm)
172.2×113.4×3.5
Net weight (lbs)
48.1lbs
Customer Reviews
Based on 4 reviews
100%
(4)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
R
Ron K.
Top product
Just to be clear with everyone this 400w kit has 2x 200w panels nobody i talked to knew this so I’m just sayin . Awesome product i had one panel hooked up to a river pro and it was charging 220w into it so I imagine 2x panel might be 440w even with light cloud cover one panel was drawing 220w . I’m a fan of ecoflow so i will be buying more products in the future . Also their customer service is pretty good too .
M
Michael L.
Late delivery
Still has not arrived.
D
DougT
Nice product
No expert but the panels work fine and look good quality. Black frame has clear plastic film attached for protection. I'm using them as portable panels in my backyard due to roof restrictions, so they are pretty weighty to try and move around but can be done by one strong person. I put some wheels on one of the panels and that helps. With both panels in series they can push out close to 600W sometimes but chasing angles and the winter sun in an obstructed space means I don't often get that, so having the two panels makes it worthwhile. Would have liked to purchase The Tilt Bracket Installation for 400W rigid panels as shown in the EcoFlow handbook but I can't find it available anywhere. The two panels were delivered on a LARGE wooden pallet of cheap quality which I now have to dispose of somehow but at least they protected the panels when the delivery guy dropped the pallet from the back of a high truck with an almighty crash!
L
Lee T.
Worked perfectly with Bluetti EP500 Pro
https://twitter.com/l33tr4n55/status/1631520236330704897/photo/1 Nice!!!
