Buy EcoFlow 110W Solar Panel — EcoFlow AU - 110W Solar Panel - Member Discount
EcoFlow Australia
$249.00 AUD
Regular price $249.00 AUD
Sale price $249.00 AUD Regular price $399.00
Save up to $150
-Foldable Power: Command Home & Wild: With up to 23% conversion rate, keep the lights on during your outdoor adventure or sudden outage.
-Extremely compact: The portable solar panel significantly reduces to 16.5*18.9*1.0 in in size when folded. approximately the size of two A4 sheets, fits in any compact space.
-Adventure-Proof, Rain or Shine : With an IP68 rating, our panels can withstand water spray and dust during your getaway trip.
-Flexible Setup: Panels can be split or combined to suit your needs.
-Versatile Power Anywhere: Ideal for home backup, off-grid cabins, and outdoor adventures.
-Perfect for Camping: Lightweight, space-saving, and easy to pack and store.
Style
$249 AUD $399 -$150
The terms "DELTA" and "RIVER" as mentioned on this page refer to products exclusively manufactured by ECOFLOW INC.
Get off the grid with EcoFlow’s 110W Solar Panel for renewable energy wherever you end up.
Universal
Seamless
Foldable
Portable
Powerfully portable
With an industry-leading 23% conversion rate, it’s far lighter and approx. 10% smaller than similar portable solar panels on the market. That means a faster, easier charge wherever you are.
Self-supportable
Take it camping, on a road trip or in your backyard with a case that doubles as a stand. Unzip and prop up your panel at just the right angle to ensure maximum solar coverage.
Waterproof & Durable
Designed to withstand your adventurous lifestyle, this seamless panel is submersible up to a meter for 30 minutes, and an ETFE film protects against ultraviolet rays.
It comes with a carry case too.
On the go? Keep your panel folded up and protected while you hit the road. Save valuable trunk space and go easy knowing your panel is safe. Once you arrive, simply unfold, prop up and start generating clean, green electricity.
Title
RIVER
RIVER Max
RIVER Pro
DELTA
RIVER
RIVER Max
RIVER Pro
DELTA
DELTA
1.110W Solar Panel 2.110W Solar Panel Bag 3. Solar to XT60 Charging Cable 4. User Manual
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
Unfolded Dimensions
70.3 x 16.5 x 10 in (178.5 x 42 x 2.4 cm)
Folded Dimensions
18.9 x 16.5 x 1.0 in (48 x 42 x 2.4cm)
Weight
13.2 lb
12 months
Rated Power
110W (±5W)
Efficiency
21%–22%
Connector Type
MC4
Open Circuit Voltage
21.8V(Vmp 18.4V)
Short Circuit Current
6.5A(Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
EcoFlow110W Solar Panel High Compatibility
How to Chain EcoFlow 110W Solar Panels
Adjust the Kickstand of EcoFlow 110W Solar Panel
EcoFlow Solar Panel Waterprrof Design
Solar Panel Connection Tutorial
Customer Reviews
Based on 62 reviews
82%
(51)
18%
(11)
0%
(0)
0%
(0)
0%
(0)
E
Evie W.
S
Selwyn N.
Ecoflow 110 solar panel
I’m not much on feedback the solar panel is great for my nets thankyou
j
josmanmay
Awesome panel...
Finally I was able to use this over the weekend and I am impressed on the performance. I was able to fully charge my Eco-flow Delta Mini while using my fridge. So I will be traveling to Moab in the next couple weeks and I am excited for I know I can depend on this. I will further update my reviews after my trip so stay tune and for now I can highly recommend it.
J
JohnP
Excellent Product
As expected a little smaller than my 160 Watt panel I got with my generator but the two connected together will work fine. VERY impressed with Ecoflow and would highly recommend them for your back up power needs. Works so well we're considering Solar for our house.
M
Mary B.
Would have given 5 stars but order was not complet
Perfect except that I ordered the suction cups as well as the parallel MC4 connector and did not receive them
