EcoFlow DELTA 2 (950) Solar Generator(PV220w)|Ecoflow Australia - DELTA 2 (950)+ Single-facial 220W SP
EcoFlow Australia
EcoFlow DELTA 2 (950) Solar Generator(PV220W)
Regular price $2,598.00 AUD
Sale price $2,598.00 AUD Regular price $2,598.00
• 950Wh Capacity (80Ah@12V)
• Huge AC output
• 7x Faster AC charging
• Or go green without sacrificing speed
• Built to last 6x longer
• Control from anywhere
• 5-Year warranty
Bundle Options
$2,598 AUD
EcoFlow DELTA 2 is not just a battery; it offers a reliable source of energy that you can take with you anywhere as well as offering home power security. With its sleek design and impressive power capabilities, this power station is perfect for outdoor enthusiasts and travelers. Plus, as backup power for your home, you can rest easy knowing that with DELTA 2 you'll always have the energy to keep things running smoothly.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Use an extra battery to expand capacity. Great for extended power outages, long camping trips, or your RV.2kWh
with 1x DELTA 2 Extra Battery
3kWh
with 1x DELTA Max Extra Battery
DELTA 2DELTA 2 Extra BatteryDELTA Max Extra Battery
2kWh with 1x DELTA 2 Extra Battery
3kWh with 1x DELTA Max Extra Battery
Power pretty much anything.
Planning a family camping trip and worried about powering all your gear? With multiple ports, DELTA 2 can simultaneously charge up to 13 devices, keeping your gadgets going all weekend long. And the best part? With an impressive 1800W AC output, power high-wattage appliances like a microwave or portable AC. Experience a power cut back home? Rest easy knowing your most important appliances will continue to run like a champ!
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Pair with solar panels and charge in as fast as 2.3 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
* With 2 × 220W Portable Solar Panel
Built to last 6x longer.
Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Ready for emergencies.
Control from anywhere.
Safety first
Safety first
1. DELTA 2 2. AC charging cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User manual 6. App quick start guide 7. Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
950Wh
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
