DELTA 2 Max 1900 Portable Power Station | EcoFlow AU - DELTA 2 Max (1900) + Smart Extra Battery
EcoFlow Australia
EcoFlow DELTA 2 Max (1900) Portable Power Station
$3,999.00 AUD
Regular price $3,999.00 AUD
Sale price $3,999.00 AUD Regular price $5,398.00
Save up to $1,399
*Note:The estimated shipping date is December 4th.
Expandable capacity: 1900Wh capacity (158Ah@12V) to fit your energy storage needs. Ideal for home backup, caravanning, outdoors or even everyday use.
Built to last 6× longer: Get 10 years of daily use until hitting 80% of its original capacity. That's down to its LFP battery chemistry giving you 3000 cycles.
Huge AC output: With X-Boost mode, get up to 3100W output power to run 99% of home appliances. Power 13 devices at once, including 4 AC outlets.
Fastest recharging: World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours
Capture more energy: 99% MPPT efficiency maximises solar generation during the daytime.
Customised in-app energy management: Prioritise solar or AC charging, view input and output power, battery levels and more.
5-year warranty:24+36 (Registration for warranty extension)
Bundle Options
EcoFlow DELTA 2 Max Bag
$159 AUD
$499 AUD $799 AUD
Charge 1kWh on a 1.3-hour drive.
$2,499 AUD
$159 AUD
$159 AUD
$499 AUD $799 AUD
$159 AUD
$499 AUD $799 AUD
$159 AUD
$499 AUD $799 AUD
$159 AUD
$499 AUD $799 AUD
$3,999 AUD $5,398 -$1,399
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 53 mins.
Up to 1000W Solar Input
Solar Charging Times
880W Charge approx. 2.6 hours
800W Charge approx. 2.8 hours
Power pretty much anything with up to 3100W output.
DELTA 2 Max powers almost all the devices you need with a large 2400W AC output. Plus, with X-Boost proprietary technology, run appliances with an output of up to 3100W. Compared with other power stations, DELTA 2 Max can power more devices, while still preventing overloading and overheating.
Plug-and-play home backup power solution
Power Through Outages
Power your essential appliances with a hefty 2400W AC output by connecting DELTA 2 Max (2kWh) and up to two Smart Extra Batteries (6kWh) with your home's transfer switch for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts.
Power for the entire family
2048Wh Capacity
A generous 2048Wh capacity makes DELTA 2 Max ideal for home backup, running your essentials for hours. With its lightweight design, DELTA 2 Max is portable enough to grab and go on the next camping trip.
Power of the entire family
2048Wh Capacity
2048Wh Capacity
*Data based on a 120W referigerator.
2048Wh Capacity
RVing & Outdoors
Home Backup
Professional Work
Filmmaking & Photography
Expandable up to 6kWh
Tripple the Power
As Quiet as 30 dB
Peaceful charging.
*From a distance of approximately 20 in., noise level is 30 dB (with low input and 500W output) vs. other power stations with 55 dB or higher.
10-year long-lasting LFP battery
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Even with its upgraded LFP battery, DELTA 2 Max is still 30% lighter than similar 2kWh LFP power stations on the market.
*Weight 23kg
With LFP cells, DELTA 2 Max is safe, durable, and highly efficient, even in warm temperatures.
A rubber anti-slip base and a fire-resistant casing offer multiple layers of protection.
Extensive 5-Year
DELTA 2 Max
DELTA 2 Max
AC Charging cable
AC Charging cable
Car charging cable
Car charging cable
DC5521 to DC5525 Cable
User manual & warranty card
1900Wh (158Ah@12V)
Extra Battery
X-Boost 3100W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 2300W, 10A
AC Input Voltage
220-240V~10A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23 kg
Customer Reviews
0%
(0)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
