EcoFlow RIVER 2 Pro(700) Portable Power Station - RIVER 2 Pro(700)+Single-facial 160W SP
EcoFlow Australia
EcoFlow RIVER 2 Pro (700) Portable Power Station
Regular price $1,089.00 AUD
Sale price $1,089.00 AUD Regular price $1,348.00
Save up to $259
- 716Wh capacity (60Ah@12V) and 800W output
- 1600W X-Boost
- Run 80% of essential appliances. Charge phones, laptops or your drone
$1,089 AUD $1,348 -$259
Power. Never Been This Easy
Charge 0-100% in 70 mins
Fastest charging speeds ever.
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes. That's 5x faster than other portable power stations on the market and 27% quicker than previous generations. Fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use1 and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
RIVER 2 Series is a cut above the rest as the first portable power station in the world to earn the TÜV Rheinland certification for safety. With it's high safety standard, the TÜV Rheinland certification means the security and reliability of your RIVER 2 is guaranteed.
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there's a recharge option no matter what. From fast AC to in-car charging when you're on the go.
AC ChargingCar ChargingSolar ChargingUSB-C Charging
The most easy-to-use independent solar power system. Take it to camping, RV trips, or run your home essentials with it. Whether you are on the go or chilling at home, have stable, durable, and reliable energy on hand whenever you need. Join hands with us in this energy-sharing world and live green.
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential home appliances smoothly for almost half a day. Sudden power outages? You'll always be ready.
Using RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 284kg. That's like planting 16 trees in a year!*
Up to 23%
Solar Conversion
Faster Solar Charging
0-100% in 4.5-9 hr
IP68 Waterproof Solar Panel
Easily Plug & Unplug10 Years of UseLong-term Saving
Up to 23%
Solar Conversion
0-100% in 4.5-9 hr
IP68 Waterproof Solar PanelEasily Plug & Unplug
*Based on an average carbon emission of 0.736kg/kWh and an average sunshine duration of 6 hours/day.
X-Boost Up to 1600W
Small size. Big power.
RIVER 2 Pro has an AC output of up to 800W. Need to power a hair dryer, microwave or electric kettle? Crank it up to 1600W with X-Boost mode to run up to 80% of high-wattage home appliances.
Lightweight at only 7.8 kg
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Learn More >
Power. Anywhere. Anytime.
1. RIVER 2 Pro2. AC Charging Cable3. Car Charging Cable4. DC5521 Connection Cable5. Quick Start Guide
Approximately 7.8kg
270 x 260 x 226mm
AC Input
220-240V~ 50Hz/60Hz, 870W Max
Solar Input
11-50V 13A, 220W Max
USB-C Input/Output
5/9/12/15/20V 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
Pure Sine Wave, 800W total (surge 1600W), 230V ~ 50Hz/60Hz
Cell Chemistry
Discharge Temperature
-10°C to 45°C
Charge Temperature
0°C to 45°C
Optimal Operating Temperature
20°C to 30°C
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)
Car Input
12V/24V, 8A, 100W Max
DC5521 Output
12.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
