Buy EcoFlow DELTA 2 + 800W Alternator Charger - EcoFlow DELTA 2 (950) + 800W Alternator Charger
EcoFlow Australia
$1,598.00 AUD
Regular price $1,598.00 AUD
Sale price $1,598.00 AUD Regular price $2,698.00
Save up to $1,100
  • Charge 1kWh on a 1.3-Hour Drive
  • FREE Energy with Every Minute Driving
  • 3-in-1 Fast Charger, Maintainer, and Battery Booster
DELTA 2 Portable Power Station
  • 1024Wh Capacity (85Ah@12V)
  • Huge AC output
  • 7x Faster AC charging
  • Or go green without sacrificing speed
  • Built to last 6x longer
  • Control from anywhere
  • 5-Year warranty
Bundle Options
$1,598 AUD $2,698 -$1,100
Top up 1kWh in only 1.3 hours
Charge 8× faster while you drive with our EcoFlow 800W Alternator Charger and recharge your power station in only 1.3 hours.
With the EcoFlow 800W Alternator Charger, charge 8 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
The 3-in-1 charger, maintainer, and jump starter saves time, money, and precious in-vehicle space.
With its smart and efficient fast charging capabilities, you'll stay powered no matter how long you're on the road.
Charging Mode
Reverse Charging Mode
Battery Maintenance Mode
Extend your RV house battery runtime
Conveniently adapts to 12V/24V RV house batteries.Connects to EcoFlow portable power stations and protects RV house batteries while expanding energy storage capacity by up to 7.2kWh*.
*With EcoFlow DELTA Pro and DELTA Pro Extra Battery
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time.The 800W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Connect your 800W Alternator Charger to your vehicle's starter battery or RV's house battery to enjoy a worry-free power experience during your journey.
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Connect the fuse cable to the input cable on one end.
Connect the fuse cable to the vehicle battery on the other end.
Connect the black cable to the chassis terminal.
Thread the other end of the input cable through the car body towards the charger. If the input cable is bulky or difficult to pull through, disconnect the cable ends before threading.
Plug the other side of the input cable into the EcoFlow 800W Alternator Charger.
Plug in the output cable from the EcoFlow 800W Alternator Charger to the portable power station.
Compatible with EcoFlow Portable Power Stations
DELTA Pro
Capacity: 3600Wh
Charging Time (By XT150 Port): 4.8 hours
DELTA 2 Max
Capacity: 2048Wh
Charging Time (By XT150 Port): 2.6 hours
DELTA Max 2000
Capacity: 2016Wh
DELTA 2
Capacity: 1024Wh
Charging Time (By XT150 Port): 1.3 hours
DELTA 2 EB
Capacity: 1024Wh
DELTA 2 Max EB
Capacity: 2048Wh
Field-Tested Performance of the DELTA 2 Max with the 800W Alternator Charger
Featured on CREEK TO COAST
Model
EF-FC-301-1
5.1 lb (2.3 kg)
Dimensions (W × D × H)
9.5×7.6×1.4 in
(242×194×35 mm)
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: <20dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: <10dBm
Charging Mode
Input: 11V-31V, 76A Max.
Output: 40V-60V, 800W Max.
Input: 40V-60V, 3A Max.
Input: 40V-60V, 21A Max.
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage protection
Undervoltage protection
Operating Temperature
–20℃ to 60℃
Storage Temperature
–30℃ to 70℃
Operating Humidity
≤95%
Storage Humidity
≤95%
Terms and Conditions:
¹The 800W refers to the speed under full power charging. The charging power is related to the car generator's current and operating condition.
Customer Reviews
Based on 4 reviews
100%
(4)
0%
(0)
0%
(0)
0%
(0)
0%
(0)
c
craigwalmsley
Power in the Van
This is fantastic, plug in and go. That’s it !
T
Timothy S.
M
Michael V.
Still wait for 2nd part of my order
Still waiting for the 2nd half of my order very hard to contact someone
P
Peter P.
