EcoFlow Delta 2 Portable Power Station: Reliable Power Anywhere - DELTA 2 - Member Discount
EcoFlow Australia
Regular price $1,499.00 AUD
Sale price $1,499.00 AUD Regular price $1,999.00
Save up to $500
• 1024Wh Capacity (85Ah@12V)
• Huge AC output
• 7x Faster AC charging
• Or go green without sacrificing speed
• Built to last 6x longer
• Control from anywhere
• 5-Year warranty
Bundle Options
$1,499 AUD $1,999 -$500
$799 AUD
Charge 1kWh on a 1.3-hour drive.
EcoFlow DELTA 2 (950) Portable Power Station
$1,399 AUD $1,899 AUD
950Wh Capacity (80Ah@12V)
1800W Output
EcoFlow DELTA 2 Waterproof Bag
$119 AUD
$1,099 AUD $1,499 AUD
$799 AUD
$119 AUD
EcoFlow Car Charging Cable
$49.90 AUD
$799 AUD
$119 AUD
$49.90 AUD
The terms "DELTA" and "RIVER" as mentioned on this page refer to products exclusively manufactured by ECOFLOW INC.
EcoFlow DELTA 2 is not just a battery; it offers a reliable source of energy that you can take with you anywhere as well as offering home power security. With its sleek design and impressive power capabilities, this power station is perfect for outdoor enthusiasts and travelers. Plus, as backup power for your home, you can rest easy knowing that with DELTA 2 you'll always have the energy to keep things running smoothly.
With a capacity of 1kWh to start with, you've got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Use an extra battery to expand capacity. Great for extended power outages, long camping trips, or your RV.2kWh
with 1x DELTA 2 Extra Battery
3kWh
with 1x DELTA Max Extra Battery
DELTA 2DELTA 2 Extra BatteryDELTA Max Extra Battery
2kWh with 1x DELTA 2 Extra Battery
3kWh with 1x DELTA Max Extra Battery
Power pretty much anything.
Planning a family camping trip and worried about powering all your gear? With multiple ports, DELTA 2 can simultaneously charge up to 13 devices, keeping your gadgets going all weekend long. And the best part? With an impressive 1800W AC output, power high-wattage appliances like a microwave or portable AC. Experience a power cut back home? Rest easy knowing your most important appliances will continue to run like a champ!
A 1800W AC output means you can power more than 90% of your home appliances. That's your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 13 devices at once for when you're around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2400W thanks to X-Boost technology.
Pair with solar panels and charge in as fast as 2.3 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
Pick from a range of solar panels to get the speed you need (110W, 160W, 220W, 400W). With that, you've got access to free energy anywhere.
* With 2 × 220W Portable Solar Panel
Built to last 6x longer.
Finally… tech that's made to last. Get years of regular use until hitting 80% of its original capacity. That's down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
Ready for emergencies.
Control from anywhere.
Safety first
Safety first
1. DELTA 2 2. AC charging cable 3. Car charging cable 4. DC5521 to DC5525 cable 5. User manual 6. App quick start guide 7. Warranty card
*The solar to XT60 charging cable is included only with purchase of EcoFlow portable solar panels.
1024Wh (85Ah@12V)
Extra Battery
4 outlets, 1800W total (Surge 2700W)
2400W
2 ports, 5V, 2.4A, 12W Max
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A, 38W Max
AC Charging
1200W
11-60V, 15A, 500W max
Car Charging
Support 12V/24V battery, 8A
DC Charging
1100W
LFP (LiFePO4 battery)
Cycle life
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
27 lbs / 12 kg
Customer Reviews
Based on 47 reviews
85%
(40)
9%
(4)
6%
(3)
0%
(0)
0%
(0)
G
Geoffrey B.
Delta 2
Delta 2 was purchased to run my sleep Apnoea machine in case of power outages.
And it arrived just in time! We have been without power for almost 48 hours here at Nelsons Plains in the Lower Hunter after a massive storm.
I have slept well thanks to the Delta running Cpap plus humidifier & heat pad.
In addition, I have a 2KVA petrol generator which charges every thing well, so the Delta is also keeping two refrigerators ticking over.
I am most happy with my purchase.
P
Peter C.
delta 2 + alternator charger
It is a good and easy solution comparing to the traditional dual battery setup, 2hour time to finish the simply setup, everything works well. Battery got charged while driving, and my fridge runs well with this battery system.
C
Customer
Ecoflow Delta 2
Awesome product and fast recharging and can cover or a wide variety of items.
J
Jimmy S.
Should have gotten a bigger one.
J
John D.
OK so far, but tech support lacking
Eco Flow delta 2 portable power station. Tested ok with freezer and shed lights.
Warning: to get the 5 year warranty, you need to register (watch the fine print) and the website won't currently let me do so. Watch this space.
