Buy EcoFlow 160W Solar Panel — EcoFlow AU - 160W
EcoFlow Australia
EcoFlow NextGen 160W Bifacial Solar Panel
Regular price $569.00 AUD
Sale price $569.00 AUD Regular price $569.00
• Portable & self-supporting
• Smart solar power
• One-piece folding design
Style
Accessories
$569 AUD
Capture more energy with a dual-sided design
With a 160W primary side, and a 125W side on the back for ambient light, you can capture up to 28% more solar energy and charge your portable power station even faster.
Generate even more energy
With the portable solar panel industry's first use of TOPCon solar technology, we've raised the bar on conversion efficiency, reaching 25%. Charge faster with a more compact panel.
Capture more solar with an adjustable angle
With a newly integrated solar angle guide and stand, adjust the angle of the panel by 30 degrees in seconds to get the most sunshine at all times.
Integrated solar angle guide
Keeps sunlight at a 90° angle on the surface of your solar panel to capture the most energy possible.
Durable and waterproof
Built for the outdoors
High-level protection
With an IP68 waterproof rating, our NextGen 160W Solar Panel maintains its high performance even when it's in contact with water. So you can recharge near a lake or take it out on your boat without worry!
Designed to withstand high temperatures while still ensuring high levels of solar generation.
Lightweight and Portable
Generate solar energy anywhere with our compact-designed panels. Fold away to store in your van or closet, pull them out in seconds to start using.
With a universal solar connector, plug and play with almost all power stations on the market, as well as EcoFlow's own.
EcoFlow Solar Panel Comparison
Original vs. NextGen
NEW
EcoFlow NextGen Portable Solar Panel
EcoFlow Solar Panel
EcoFlow Solar Panel
Cell Type
N Type TOPCon
monocrystalline silicon
P Type PERC
Conversion Efficiency
Weight
(5.1 kg-7.2 kg)
(5.6 kg-9.5 kg)
Stand Type
30-60° Integrated Adjustable Stand
Separate Kickstand Case
Additional Feature
Integrated Solar Angle Guide
No Solar Angle Guide
What’s in the box
XT60i Charging Cable
Protective Bag
Protective Bag
Quick Start Guide, Safety Instructions & Warranty Card
Rated Power
160W(±5W) Front/125W Rear
Cell Type
N Type TOPCon monocrystalline silicon
Efficiency
25.00%
Weight (Solar Panel)
Approx. 5.1kg
Unfolded: 615 x 1628 x 25mm
Folded: 615 x 586 x 32mm
Connector Type
MC4
Warranty (US)
12 months
Open Circuit Voltage
21.3V (Vmp 18.6V)
Short Circuit Current
9.1A (Imp 8.6A) Front Side/ 7.1A (Imp 6.7A) Rear Side
Waterproof & Dustproof
