The terms "DELTA" and "RIVER" as mentioned on this page refer to products exclusively manufactured by ECOFLOW INC.
Compact and portable, EcoFlow RIVER is an ideal recreational power which gives you the accessibility to handy wall outlets. EcoFlow RIVER is the perfect companion for camping, overlanding, tailgating, boating, etc. Feel free to attach and detach the Extra Battery to meet your needs now and later.
How to install EcoFlow RIVER Extra Battery?
1. Please make sure that the EcoFlow RIVER is turned off. Take out the screwdriverfrom the extra battery module kit and locate the four screws on the bottom cover.
Note: Please pay attention to prevent static electricity during the installation process.
2. Please remove the 4 screws and the bottom cover. The extra battery module should be positioned as shown in the figure.
3. Align the male and female battery sockets and connect them. Close the bottom cover. Take the four long screws from the kit and screw them on the screw mouth.
4. Put the EcoFlow RIVER upright and turn it on. The extra battery's ambient light will turn on. If the extra battery module indicator light is shown on the EcoFlow RIVER 's display, it is activated successfully. If the ambient light or the extra battery module indicator light is not active, repeat the installation steps and then check the connection.
Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances.
Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
What EcoFlow RIVER + Extra Battery Can Power?
*The duration and times of the appliances indicated in this table are for reference only.
Specifications
General Info
5.5 lbs (2.5kg)
11.2 x 7 x 2.3 in (28.5 x 18 x 5.9 cm)
Charge Temperature
32-113°F +/- 5°F (0-45°C +/- 3°C)
Discharge Temperature
-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color
Black
24 months
Battery Info
288Wh (28.8V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (after fully charging the device)
500 Cycles to 80%+ capacity
Testing and certification
UL Standard CE FCC RoHS RCM
Product
Quantity
X 1
Long Screws
X 4
Cross Screw Driver
X 1
User Manual
X 1
The shelf life of RIVER is up to a year, but in good storage condition. In order to maximize the life span of the battery we still recommend you discharge RIVER to 30%, then charge to 85% every 3 month.
1) When AC output is between 0-400W, the sound level is around 42 dB at 1 meter from RIVER, which is simialr to the sound level in the library.
2) When AC output is between 400-600W, the sound level is around 48 dB at 1 meter from RIVER, which is similar to the sound level in the office.
3) When charging RIVER through X-Stream AC input, the sound level is 45 dB at 1 meter from RIVER, which is simialr to the sound level in the office.
4) When charging RIVER under quiet mode, the sound level is 40 dB at 1 meter from RIVER, which is simialr to the sound level in the library.
Yes. You can connect 1*110W solar panel or 2 sets of 110W solar panels in parallel to get more solar power.
There are two methods to connect: Using Wi-Fi:
a. Long press the IOT Reset button on RIVER until you hear a “beep” sound.
b. Find the device in the Wi-Fi setting on your phone. Click the device to connect.
c. Go back to the EcoFlow App. Click the + on the top right to start connection.
d. Tick the “operation confirmed” and proceed to the next step.
e. Choose the Wi-Fi and enter the password to proceed.
f. Wait until the connection is finished. Using Hotspot: a. Long press the IOT Reset button on RIVER until you hear a “beep” sound.
b. Find the device in the Wi-Fi setting on your phone. Click the device to connect. c. Wait until the connection is finished. If your device successfully connect with your app, it will appear on your "Devices" list.
RIVER supports an entry-level UPS function. But please perform multiple tests to confirm compatibility before connecting devices such as data servers and workstations with RIVER . EcoFlow will not be responsible for any loss of data or equipment damage caused by customers' failure in following the instructions.
The firmware can be upgraded using the EcoFlow App.
a. Make sure the RIVER is plugged into AC power source or has at least 50% power and System Power is ON.
b. Disconnect all other input or outputs from the RIVER .
c.Make sure the 2.4 GHz WiFi router signal is strong.
d.On the System Settings page, tap "Update" button
e.Four packages will be downloaded and installed. While this happens the icons on the LCD display may flash which is normal.
f. Close and reopen EcoFlow App and verify the new Version number appears on the Device System page.
a.Make sure your APP is connected to the device you need to use.
b.Make sure that your device is on.
c.Make sure the Wi-Fi your device connected to is on.
d.Find your device in the APP then explore the functions you would like to accomplish remotely through the APP
Click "AC" on the device page of the APP, and you could turn on the "X-Boost" function after entering the page.
*In order to save power, it is recommended to turn off the X-Boost function when you don’t need to use it.
*X-Boost technology's built-in advanced algorithms would be able to run devices with up to 1200W per draw, but it is recommended to test before use. *X-Boost mode is NOT suitable for ALL appliances. Some 600W-1200W appliances with strict voltage requirements may not function (eg. air compressor). Please test to confirm before using the device. X-Boost mode is enabled by default. You can disable it on the APP.
Find your devices on the “Devices” Page, go to the “System” button, then you will find the firmware version by clicking “Version” on the system page.
Open the APP, find "Help & Feedback" under the user page, and click "Feedback"
User Manual
Click to Download EcoFlow RIVER Extra Battery User Manual
I love the flexibility to allow some expansion. It doesn't add too much extra weight and still convenient with the handle, easy to install and provides some extra juice to use. Nice integration with the app too.
R
Rebecca S.
Great battery we love the extra boost
M
MattB
Extra juice in the caboose
Perfect for that little extra when you need it. Makes the unit a really good travel companion in the car or on the boat. Charged for free by the GA Sun is a win!
D
Dominic M.
Great product to expand functionality!
Very easy to throw it on, works perfectly and I'm super impressed with the extra battery as well as the ecoflow river
C
Customer
Easy peasy
Perfect less than 5 min to install. Works great heavier though.
