EcoFlow DELTA Max Solar Generator (PV400W)- EcoFlow Australia - DELTA Max (1600) / 1 - EcoFlow Australia
EcoFlow Australia
Regular price $3,798.00 AUD
Sale price $3,798.00 AUD Regular price $4,298.00
Save up to $500
Up to EcoCredits for cash deduction
• Home emergency power
• Rapid dual charging
• Power multiple devices
• Highly Efficient Solar Panels
• Self-supporting
• Durable and Lightweight
• Weatherproof
Model
Number of Solar Panel
$3,798 AUD $4,298 -$500
EcoFlow DELTA Max Extra Battery Cable
$109.90 AUD $119.90 AUD
EcoFlow DELTA 2 Max/ DELTA Max Cover
$159 AUD
EcoFlow DELTA Max Smart Extra Battery
$2,099 AUD $2,499 AUD
$159 AUD
The terms "DELTA" and "RIVER" as mentioned on this page refer to products exclusively manufactured by ECOFLOW INC.
Expandable Capacity
Dual Charging
Power Multiple Devices
Solar Power
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3600W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.
With EcoFlow’s X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the MC4 connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 10A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
AC Output (x4)
Pure Sine Wave, 2400W total (surge 4600W), 230V~ (50Hz/60Hz)
3000W
USB-A Output (x2)
5V 2.4A, 12W max, per port
USB-A Fast Charge (x2)
5V/2.4A, 9V/2A, 12V/1.5A, 18W Max
USB-C Output (x2)
5/9/12/15/20V 5A, 100W max
Car Charger Output (x1)
12.6V/10A, 126W max
DC5521 Output (x2)
AC Charging Input
2000W Max, 10A
Solar Charging Input
11-100V 13A Max, 800W max
Car Charging Input
Supports 12V/24V Battery, Default 8A
NCM
800 cycles to 80% capacity
Shelf Life
1 year (after a full charge)
Connection
Wi-Fi
Approx. 22 kg
Dimension
49.7 x 24.2 x 30.5 cm
Specs of DELTA Max (1600)
1612Wh
Extra Battery
AC Output (x4)
Pure Sine Wave, 2000W total (surge 4600W), 230V~ (50Hz/60Hz)
2500W
USB-A Output (x2)
USB-C Output (x2)
12.6V/10A, 126W max
DC5521 Output (x2)
AC Charging Input
1600W Max, 10A
Car Charging Input
NCM
500 cycles to 80% capacity
Shelf Life
Connection
Wi-Fi
Approx. 22 kg
Dimension
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.40%
41.7*93.1*1.0 in (105.8*236.5*2.4cm)
Connector Type
MC4
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 27.6lbs (12.5Kg)
Weight (with Kickstand Case)
34.2lbs / 15.5kg
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Customer Reviews
Based on 202 reviews
84%
(169)
16%
(33)
0%
(0)
0%
(0)
0%
(0)
R
Robin
Love it
B
Billy
Solar panel
I love it, but it is very heavy, but I will buy other solar panel.
A
AZZL
Perfect!
Excellent !!! Bought it literally one day before a 10 day power outage hit our area. Great supplement to when you don’t want to run the generator.
E
Ed C.
FIrst use review
My new Delta Max 2000 is installed in my outside shed which is within 10 feet of the side garage door. I installed a 4 pole L14-20R receptacle on the outside of the wooden shed that will be used for the Derlta Max AC output. A transfer switch and cable are in the garage. Also added to the shed was a NEMA 5-20 plug for the Delta Max AC input charge line. Next will be 400 watt solar panels on the roof. Today I powered both my washing machine AND the gas dryer doing two loads. The Delta Max worked fine and when the wash was done it had only dropped down to 70%. Amazing, quiet power source. The spare battery just arrived so that's going in right away. The phone app is a nice touch to keep an eye on loading and charge rate.
M
Max S.
Great Product for Critical Home Backup
I purchased a few of these as backups for my sump pumps. The Delta has the power output and storage capacity to last for days. Plus the ability to monitor and control them remotely is great for peace of mind when we are away.
